Question about Rotel Audio Players & Recorders
Not playing in stereo
Im running a Rotel RC 850 and two Rotel RB 850's. I have it wired so one power amp runs the bass and the other the top end. It used to work ok and ive changed nothing. The ON/OFF-MONO tone knob would sometimes bring the stereo back if i switched it back and forth.
  •  Mark Roberts
    Mark Roberts Oct 18, 2012
    Imput is from a Technics SL-PG560A. Speakers are Bi wired Accustic Energy AE109. When i say it was ok , i ment its not been used or dismantled but now has this fault. Ive rewired so each power amp so each amp runs each speaker and i get good sound from one speaker but only a very faint sound from the other speaker. I was thinking ive a problem with one of my power amps. Thanks for your imput David.
    Sergeant:
    Champion:
  • 274 Answers
You have blowin a IC in it, Power amps are not suppose to be use for the purpose you were useing it for.You are dam lucky they didn,t go up in smoke.
Posted on Oct 22, 2012
  •  Mark Roberts
    Mark Roberts Oct 22, 2012
    absolute rubbish. A CD player going through a Rotel RC-850 and two Rotel RB-850's. With a pair of AE 109 speakers. WHY is this wrong????????
  • greg degelman
    greg degelman Oct 22, 2012
    Because i brought a adcom power amp from a guy last winter,End had had it hooked up the same way you had yours hook up.Where the IC for the left chanel was fried .End i am a retired Eletronic Technicain,After working at it for over 40 (Years) Idiot.)
3 Suggested Answers
SOURCE:
  • 561 Answers
SOURCE: I have no sound coming from my amp a rotel rb 981
it is never advised to change wires while the amp is switched on. you may have blown your diodes on your post amp then you have a problem.
have you tried other speakers tested your speaker on another system to rule them out as OK?
if you open the case be careful not to touch any large capacitor as they may still be chared and can give you a nasty belt.
any fuses should be easy to find and to see if they are blown. ensure you get the same rate fuse when you replace. if you see any charing of diodes then i think repair may be costly. good luck.
Posted on Nov 12, 2009
doron_c21
  • 387 Answers
SOURCE: left channel doesnt produce sound as vu meter
Hi
from your description it looks like the switch causing this problem
replace the switch might solve this problem unless its cause some short on the main circuit
if you want to fix he Amp let me know
ecrdn@yahoo.com
Jack
Posted on Oct 21, 2010
Car stereo problems
Do you have an amp? Remote wire might have come loose and the amp is telling the speakers to stop playing. Or, you might just have a setting problem, like it\'s turned on to just the rear and the rear is set to sub. Try dinking with the settings and running flat eq....(+/- 0 on bass treb and mid). If not, then there is a master plug in the back of the system: unplug and plug back in. If none of this works, trace the speaker wires back and make sure they are connected and not melting somewhere hot.
Jun 17, 2013 | Car Audio & Video
Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Aug 02, 2012 | Audio Players & Recorders
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
No sound to remote speakers in dining & deck areas.
Incoming from WHAT? Ampifiers accept inputs via RCA connections and send amplified audio to the speakers via the + and - OUTPUT terminals.
I'm guessing your colored wires are from your speakers and that there is a piece of this puzzle we do not see - how the speakers on the deck and in the dining area are wired.
You say, "was working ok previously"... previous to WHAT? Something changed.
You can probably troubleshoot and resolve this yourself.
Set the amp to a medium output level.
If the wires are simply leading to either or both pairs of speakers you could select any two of them and connect them to one side of the amp. Only a pair going to the same speaker(s) will produce sound. Once you identify one pair, the other pair probably goes to the other speakers. Connect them to the other channel output.
The last piece would be to establish correct phasing between the speakers. Bass response will suffer if they're not IN-phase. Play something with substantial bass. Listen closely, then reverse the wires on one side only. Test again. If it IMPROVES you have it right. If it losses bass, put the wires back the way they were.
Apr 27, 2010 | Rotel RMB-1095 Power Amplifier
I have no sound coming from my amp a rotel rb 981 and rc 980bx . I was changing speaker wires and am afraid i have blown a fuse [but cannot find external one]. powers up but no sound
Nov 12, 2009 | Audio Players & Recorders
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
May 09, 2008 | Audio Players & Recorders
Free booklet/part #149393
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
129 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
