Lost the manual and need to know how much water to use for that model
SOURCE: West Bend 36 cup coffee maker amounts
It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
SOURCE: I need an instruction manual
Here is the manual:
http://www.focuselectrics.com/supportdata/L5563G_55108-3in1_All.pdf
-Tha Mp3 Doctor
SOURCE: want to know a quick and simple way to descale my maker!
you can use white vinegar to clean your machine put i part vinegar to 4 parts water into the tank with no coffee turn on the machine let the machine empty then: run the machine 4 more times with plain water
SOURCE: Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
SOURCE: need manual for a JC Penney Cooks Espresso Maker
I have the same problem. My model number is TSK1842A
