Question about Kipor Generator Diesel Kde5000ta
Kipor Generator Diesel Kde6700ta P01 fault - Kipor Generator Diesel Kde5000ta
3 Suggested Answers
SOURCE:
CarlGehrke
  • 169 Answers
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
  • 342 Answers
SOURCE: My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
Posted on Apr 04, 2010
KIPOR KDE6700TA no oil pressure, while
fill the sump to the correct level
check /replace oil level sensor system
Jul 22, 2018 | Kipor Electrical Supplies
Kipor generator 6500 starting and stoping after few minutes running what could be the problem Diesel model
Im taking it as the engine is cutting out?
Is this a diesel model?
Try, low oil cut off, fuel tank not vented correcly, fuel blockage.
Feb 25, 2018 | Kipor Electrical Supplies
How to reset Kipor KDE6700TA P06 emergency stop code.
Error P-06 is the failure of the emergency stopping button. Replace the emergency stopping button or if possible check for repair.then by pushing rest/clear button reset the alarm and start the engine. https://assets-cf.criticalpowersupplies.co.uk/.../Kaipor_KDE12STA3_Silent_Generator.
Oct 27, 2017 | Kipor Electrical Supplies
My kipor 7000 diesel generator is burning avr. Replaced avr don't last beyond few days. Can someone tell me cause
You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
Jan 11, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Why unit keeps shutting down after it starts.
Your question is general without specific details. Any one of many things will cause your generator engine to stop running.
Is this question about a Kipor KDE5000TA? If so, your generator is powered by a diesel engine. There are safety shut downs built into the generator to protect the generator head and engine. Do you have any fault codes showing on your control panel display screen? (Trouble codes P-01 through P-05 will be displayed if there's a detected fault)
If you have no fault codes, then you likely have a fuel problem. Do the obvious:
  1. Visually check the fuel level in your tank. DO NOT rely on your fuel gauge. It may be stuck or otherwise not working.
  2. If you have fuel, check your fuel filter. It may be clogged. If your fuel filter is good, you may have water contamination.
  3. Drain your tank and refill with fresh #2 diesel fuel. I use "Diesel 911" with a biocide to prevent water contamination and bacteria growth in my fuel.
  4. Make certain your fuel oil supply and return lines are clear, not leaking, and the fittings are tight.
I know I'm shotgunning, peppering the target. However, I don't have enough information to zero in on a specific area where the problem could be. Good luck!
Apr 26, 2015 | Kipor Generator Diesel Kde5000ta
Kipor 6700ta po5 code problems , diesel silent generator
1. Check the voltage of battery whether is 12V or 24V; 2. The voltage of battery is low when the generator is still, then it is necessary to dismantle the battery and charge the battery with charger.
3. If the voltage of battery is low but the generator is running, it indicates that the diesel engine driven charger doesn't work; then it is necessary to stop the engine to check the fan belt.
4. if the fan belt is not loose, please check the charging AC diesel engine driven charger, please refer to Manual for Diesel Engine.
5. If the battery can not store the electricity, please replace the battery for a new one. https://www.dieselgeneratortech.com/generator-sets/discovery-and-elimination-of-faults-of-the-control-system.html
Feb 04, 2014 | Kipor Electrical Supplies
Kipor Generator Diesel Kde5000ta Logo
775 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
