Question about Necchi 6015 Mechanical Sewing Machine
Feet not feeding and thread bunching up - Necchi 6015 Mechanical Sewing Machine
  • Necchi Master
  • 7,365 Answers
The presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Posted on Oct 16, 2012
  • Jean Jacobs
    Jean Jacobs May 28, 2014
    I have the manuel. I tried cleaning under the bobbin, unscrued the plastic plate under the machine and cleaned. I put the plate back and now the lever to lower or raise the feed dogs is not working. How can I fix it?
SOURCE:
The bottom feet keep catching my thread and stopping
try increasing the needle thread tension as what you indicate is bunching under the material from a needle thread with a too loose tension
Jul 17, 2016 | Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
When i try to use it it doesnt thread with the bottom thread and bunches up and breaks the top thread. i cant find this model online!!: please someone help! dont know if i threaded properly
Possible problem is the bobbin inserted the wrong way round. I'm not familiar with this model, but if you've checked the upper threading, and it's still bunching, make sure the bobbin thread feeds off the bobbin correctly (e.g. either to the right, or to the left, as it's inserted). Hope this helps.
May 02, 2015 | Brother Sewing Machines
What is the cause of thread bunching up on the bottom
dirty machine clean the feet dogs and make sure threads are free of any gears.
Oct 07, 2014 | Sewing Machines
Why does the top thread on my brother sewing machine bunche up on the bottom side of my material?
The routine answer is that the top tension isn't working correctly. There may be a bit of lint or thread caught between the tension discs. Try taking a length of thread about 3 feet long and feed it into the tension and pull it out again several times. Thread the machine with the presser foot up until ready to thread the needle. then lower the presser foot and check for tension. If OK thread the needle and begin sewing. If not, start over by pulling thread through the tension.Then repeat trial. If still not OK, send the machine in for service. Good luck.
Jun 13, 2014 | Singer 2662
Top thread - not bobbin thread - bunches up under fabric where feed dogs are when I'm embroidering.
this is a top thread tension problem . make shure thread is between tension plates and spring is contacting the plate if the tension number is high
Apr 12, 2010 | Baby Lock Ellure
I have a WHITE 3300 EMBROIDERY MACHINE and the thread bunches up at the bobbin site. I have tried a new needle, adjusted upper thread tension , changed bobbin threads and nothing helps, it keeps bunching...
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Mar 18, 2010 | White Sewing W3300 Computerized Sewing...
Thread bunches up from bobbin feed.
Remove the needle plate and clean the feed dogs there could be fluff gathering.
Check your needle is not damaged.
May 30, 2009 | Singer 1120 Mechanical Sewing Machine
Bobbin thread bunching
tension is tooooo loose.
slowly tighten
also the pressure gauge at the top should be for accurate fabric thickness
May 30, 2009 | Janome Memory Craft 3000
Necchi 6015 Mechanical Sewing Machine Logo
3,572 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
