Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Anonymous Posted on Oct 16, 2012
Head temperature sensor rank error - Canon PIXMA MP530 All-In-One InkJet Printer
Refresh Cartridges
Level 2:
Sergeant:
  • Expert 241 Answers
  • Posted on Oct 16, 2012
Refresh Cartridges
Expert
Level 2:
Sergeant:
Answers
241
Questions
0
Helped
75336
Points
609
There is not an easy fix for this sadly. "Head temperature sensor rank" is typically a case of calling a technician or chucking it in the bin depending on how much the printer is worth to you.
Testimonial: "Thanks for comment. I had to order a new printhead. It's cheaper for me to fix the printer than to buy a new one and get scalped on newer ink cartridge models that have not yet "after market" reinkable solutions. "
  • Anonymous Oct 16, 2012
    I put in the old printhead the faulty one had replaced (bad color on the old one) and the error went away.... so I ordered a new printhead. I "standardized" my office printers by adding a ip4500 (same cartridges) so in theory I could swap print heads to do some copying. I wouldn't mind paying good money for any printer in the future IF: 1) cartridges could easily be reinked (like the MP530/iP4500), 2) It were to be as user serviceable as possible. There was a time when I could get a new MP530 for $60+ on internet after I had paid $99 for one. My son bought it but I would have bought a few to have parts...
1helpful
3answers
Does 2005 Ford Focus Zx3 2.0 engine have a Coolant Temperature Sensor? I replaced the Cylinder Head Temperature sensor between spark plugs. Does 2005 have ECT sensor?
Only has CHT sensor no coolant temp sensor .
SECTION 303-14: Electronic Engine Controls 2005 Focus Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 02/25/2004
Electronic Engine Controls The electronic engine controls consist of the following:
  • Powertrain control module (PCM).
  • Throttle position (TP) sensor.
  • Idle air control (IAC) valve.
  • Cylinder head temperature (CHT) sensor.
  • Camshaft position (CMP) sensor.
  • Crankshaft position (CKP) sensor.
  • Power steering pressure (PSP) switch.
  • Mass air flow (MAF) sensor.
  • Heated oxygen sensor (HO2S).
  • Catalyst monitor sensor(s).
  • Knock sensor (KS).
  • Fuel rail pressure and temperature sensor.
  • Fuel pump driver module (FPDM).
How to fix error 5B00 on Canon Mg5350
The print head is not installed [1401], or it is not properly installed (Print head temperature sensor error [1403] / Faulty EEPROM data of the print head [1405]).
If you wish to get more details about this; visit the site linked here; after an hour.
Does anyone know how to rectify the TEC B-SX4 head temperature error? it's the correct version printhead for the model of MLB and the correct firmware, but problem still exists.
This excess temperature may be caused by a temperture detector.
Ther are two detectors on a Toshiba Tec Printer.
- On the print head.
- In the top part of the label sensor mecanism.
You cna check if they are working when going in the adjust set parameter setting.
You can read Head temp and air temp
If one of them is not working you will not be able to adjust the temperature. Worst you'll have the message Head excess temperature message.
2answers
Canon MP660 U052 Error
Remove and reinstall your Printer Cartridges. Else, you will need to take your printer to a Canon Service Center to have them replace your faulty Print Head / Temperature Sensor that is causing the U052 Error.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
10helpful
Service error 5200. on a cannon s750 does this mean i have to buy a new printer
Orange error 5200 Abnormal head Green temperature error The head temperature (output of the diode sensor 8 toggle blinks in the head) is close to the threshold Print head, logic board. this mean buy a new (:
We are bakeing and every time we set it in a couple it shuts down and F_3 apears what would cause this?thanks 4 help
first thing to do would be to test the oven tempreture sensor by conducting an ohms test on it at room tempreture should be reading between 1000-1100 ohms if it were less then replace it this fixes the f3 error code only 90 percent of the time on other occasions it could be both the tempreture sensor and the control board 10 percent of the time but seeing how the tempreture control sensor is far cheaper test that first and if it fails replace the sensor and also make sure you check the wiring to the sensor and to the control as well it says directly in your service manual this
F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks again Rick
2helpful
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
2answers
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
4helpful
Ip 4200 blinks 5 times
This error is the print head is not installed
[1405]).
12helpful
2answers
THS Error on warrantee printer tally serial printer
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
old marine
old marine
ZJ Limited
ZJ Limited
