Razor MX350 DIRT ROCKET - BLUE Logo
Stevie J Posted on Oct 15, 2012
Dirt bike wont go - Razor MX350 DIRT ROCKET - BLUE
Jenny Theiss
Level 1:
New Friend:
  • Contributor 53 Answers
  • Posted on Oct 25, 2013
Jenny Theiss
Contributor
Level 1:
New Friend:
Answers
53
Questions
Helped
31078
Points
55
Have a look at the Trouble shooting guide here
http://www.razorama.com/razor-installation-guides.html
The wiring diagram can be down loaded here
http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
the owners manual can be down loaded here
http://www.razorama.com/razor-owners-manuals.html
Dirt bike wont run. I have replaced the stator and pickup coil, the regulator, grounded out the neuatral safty switch, and bypassed the kill switch. I get a great spark about every 6 to 10 kicks
7 Things To Do When Your Dirt Bike Won't Start - All
www.instructables.com/.../7-Things-To-Do-When-Your-Dirt...
InstructablesSometimes when your dirt bike does not get used, it won't start.Here are some ways to start a "mad motor."
What To Do When Your Bike Won't Start - Dr. Dirt - Dirt Rider ...
www.dirtrider.com/features/protips/141_0803_dr_dirt_bike_wont_start
Apr 6, 2009 - Tech How-To****There are few things more frustrating to a rider ready to ride than a motorcycle that won't start. But a silent machine need not ...
So, Your Dirt Bike Won't Start? - Cannibal Cycle
Dec 15, 2015 • Motorcycles
2answers
Theres no spark and bike wont start
you will have to check lead to spark plug then lead to coil
if your not getting spark at plug it could be a number of things ingintion
or just a loose wire best of luck hope you solve it
I have a razor dirt bike it has 3 12volt batteries .i replaced the battery modual because it was melted but it still wont work
If the battery was melted, that would suggest a bigger problem replacing the battery wont fix - the wiring and switches are probably fried and need servicing/replacing
1helpful
Hi, my son has an electric razor quad bike with two 6 volt batteries. We have just replaced both batteries and the full charge light shows when you switch it on but it still wont start up. Can you...
The batteries should be 2 x 12v giving an output of 24v anything less than this the Razor Dirt Quad will not run. always make sure you buy genuine Razor replacement batteries.
2answers
Yamaha dirt bike igniter
Try looking at a workshop manual .if possible ,or contact you local dealer .
2helpful
1helpful
I left the bike in my garage and now it wont start, what could i do?
hi friend,
Move switch to ON position
Locate your dirt bikes OFF/ON, RUN/OFF, or START Switch. Use your finger to move the switch to the RUN, ON, or START position.
  • Step 212233_65x95_aspect.jpg Turn fuel switch ONLook on the side of your dirt bike near the engine and locate the "FUEL ON/OFF" switch. Use your finger to move the lever to the "ON" position. Your dirt bike will not start if the fuel is turned off. This off switch helps prevent fuel leaks when your dirt bike is stored.
  • Step 312234_65x95_aspect.jpg Turn choke ONIf your dirt bike engine isn’t warm, you will need to turn the choke on to start the bike. Locate the choke lever near the engine on the side of your dirt bike, probably not far from the "FUEL ON/OFF" switch. Use your finger to move the choke lever to the on position. Once your dirt bike has started and the engine has warmed up, you will need to move the choke lever to the "off" position.
  • Step 412236_65x95_aspect.jpg Foot on kick start pegBend your knee and place your foot on the kick start peg while leaning your weight on your other foot. Stand slightly and push the kick starter all the way down with as much force as you can.
  • Step 512239_65x95_aspect.jpg Push all the way downIf the bike doesn't start after the first attempt to kick start it, try again. Remember to push the peg as far down as it will go with as much of your weight as possible.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If your dirt bike has a four-stroke compression engine and won't start, release the compression valve and try starting it again.
    • Sometimes, the engine remains in a compressed position and cannot turnover until the pressure is released.
    • If your dirt bike is equipped with an electric-starter, but won't start, you can follow these steps and kick start it.
    • Remember: always wear safety equipment when operating a dirt bike or ATV.
    • You should at least wear a helmet, boots that cover your ankles, and a chest protector to avoid serious injury.
    • Always supervise children when operating motor vehicles.
    hope this helps u
    please rate me.......................
    thank u for using fixya
    regards
    sivaranjini
    Top Razor Cycling Experts
    ADMIN Eric
    ADMIN Eric
    vince
    ADMIN Andrew
    ADMIN Andrew
    Are you a Razor Cycling Expert? Answer questions, earn points and help others
