Control panel active. When press start, displays "drying" for a second, clicks, then displays "paused". Dryer never starts. Code generated is: E52 Motor. Do I need to replace the motor?
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
SOURCE: Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
SOURCE: Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
SOURCE: Fisher Paykel Dryer Model DE08-US1. Dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: My Samsung DV219AGW/XAA dryer has no error codes.
heatman101
