Question about Coby Electronics Corporation Coby Kyros MID9742-8 9.7" 8 GB Slate Tablet - Wi-Fi - Allwinner Cortex-A8 1 GHz
Coby kyros mid9742-8 stuck on loading screen
I keep restarting it and it wont finish the start up
    New Friend:
  • 3 Answers
It's the computer. needs reset in set
Posted on Oct 15, 2012
SOURCE:
How can I fix a froxen logo screen on a Kyros tablet?
you should give it to shop no other way. But the trick should work. press the button for 40 sec try it
May 19, 2015 | Coby Kyros Internet Touchscreen Tablet...
How to fix kyros coby mid8024 tablet
Sounds like a corrupted kernel. The only thing you can do is download adb tools and then download the original Coby files for android. without having to do alot of research(if you dont know how to, you will have to research) you can go to Androidcentral.com go to the coby section, in the forum. There you should be able to find the step by step method. Sorry but this would be about the best help I can give you with out actually doing it myself.
May 10, 2015 | Coby Kyros MID80244G Tablet
My coby kyros power button is stuck how can i fix it
Try opening the kyros on the babk might be hard but woth it text me back tell a perent or someone to open it you might do damage
Oct 20, 2014 | Coby Kyros 7" Touchscreen Tablet
Coby mid8065
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
May 31, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
My tabet wont turn on
First make sure your charger is working properly. Check it with a volt meter or use a friends charger that you know is working. Charge your Coby Kyros for 4 hours. Use a small needle and gently insert in into the "reset" hole on the back cover on the left side. Hold it down for 5 seconds then release. Try restarting your tablet. If these don't work, you will have to get professional help to check it out.
Feb 12, 2014 | Coby Kyros 716829701508 Tablet PC
Coby kyros MID 7022 wont unlock main screen....swiping only meets halfway then screen goes black..help?
ok try the reset button plug the power cord before you start. look where is the reset and use a small point toothpick .
Nov 03, 2013 | Coby Kyros 7" Touchscreen Tablet
Coby kyros mid 7015 stuck at logo screen how do i fix it
Take out the battery for at least 4 hours and just let it sit. Put it back in and it should be fine
Oct 17, 2013 | Tablets & eReaders
My coby screen is frozen
i forgort my password on my coby kyros i tried to reset but it keeps going to my password
Mar 22, 2013 | Coby Kyros 716829701508 Tablet PC
Coby Electronics Corporation Coby Kyros MID9742-8 9.7" 8 GB Slate Tablet - Wi-Fi - Allwinner Cortex-A8 1 GHz Logo
599 people viewed this question
Top Coby Electronics Corporation Tablets & eReaders Experts
Sheldon Dedek
Stan Ford
Rigger
Are you a Coby Electronics Corporation Tablet and eReader Expert? Answer questions, earn points and help others
