Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd or Microsoft .NET Framework 2.0 must be installed
hope this helps
SOURCE: Cannot turn off Acer Aspire T650
Please type shutdown -s in run option or try in safe mode if happening then reinstall the chipset and graphics drivers.
2.if the issue is not resolved then you may have to reinstall the OS.
SOURCE: Having problem installing Windows XP on My Acer Aspire T650 Computer
Before you did the install did you make sure that you set your CMOS setting to check for a cd disk first before booting straight to the hard drive? When you do an install, you must make sure that the computer knows to look for a bootable disk otherwise it will look for an operating system to boot to first. If this is the problem, after you have installed your operating system you must go back and reset your CMOS settings to look for a hard drive or operating system. Hope this help and if it doesn't let me know for further assistance.
SOURCE: how to install window xp on aspire t650
Well yes you can install windows xp without the FDD. But it will be best to first gather all the XP compatible drivers for your Acer Aspire T650 at this link http://global.acer.com/support/index.htm before beginning to downgrade your operating system, burn all your XP drivers into a Disk backup your personal file. Then you can begin the installation.
SOURCE: PC Desktop Aspire m1641 new pc desktop sata driver link ..
you download driver from this site.
http://komku.blogspot.com/2009/01/aspire-m1641-m3641-m5641-windows-xp-and.html
SOURCE: coprocessor driver for windows 7
Try letting Windows update detect and install the coprocessor driver for you.
You may have to perform the Windows update a couple of times before the device is detected.
When you start windows update it will give you a list of software and drivers that are available, you will in the list that there are optional updates available. Check there to see if the coprocessor driver is there and install everything except for the language packs.
Hopefully this will resolve the problem for you.
Good luck.
If you were to log on to the acer.com web site, I think you may be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
how to install windows 7 on aspire t650 desktop pc
EXCELENT
