My old computer has my camera software on it, how do I transfer to my new imac, will it work, and what do I need to know.
You don't need any additional software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
SOURCE: Canon Powershot SD1000 Uploading Pics To Computer Problem
ugh this happened to me too :( it sucks cuz i have had great pictures i wanted to upload but they wont upload :(
SOURCE: find cd software download for canon powershot SD1000 I lost my original cd
Which operating system do you have? Windows? mac? if it is windows which version? You should not need a lot of software to use the camera as you should be able to connect the camera and see the pictures (mac os 10.4 and windows XP/vista)
You can try going here to see if any of the software will help you:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=14901#DownloadDetailAct
You will have to select your operating system before it will show you any software otherwise you will only get the manuals.
Hope that helps
SOURCE: canon digital camera solution disk
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the USB cable and run the
software that you downloaded.
The software installer will tell you when
to connect USB.
Since your two cameras have the same problem with the same computer, I would like to suggest you to connect those cameras to another computer. It looks like the problem is on the computer side.
