My DVD RECORDER DMR-E70V KT 3K A033056 2003 JQA IS JAPANESE MANUFACTURED UNIT AND HENCE THE LANGUAGE OF THE SET IS JAPANESE, WHICH I AM UNABLE TO CONVERT INTO ENGLISH AND WHILE TRYING SO I HAVE ALSO LOCKED THE REMOTE CONTROL OF THE UNIT. WHAT SHOULD I DO TO SOLVE THIS PROBLEM.
Http://www.ehow.com/how_5968779_unlock-dvd-player.html
please go to that page and proceed. read your instr, manual how to change the languaje, or download from www.retrevo.com
God bless you
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
SOURCE: Panasonic DVD Recorder DMR-ES10 Remote Control
Your player and recorder are, most likely, on different codes. Press and hold ENTER and 2 on the remote for at least two seconds and you should be home and dry!
SOURCE: panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
SOURCE: Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
SOURCE: machine stuck on remote dvd 2 setting
Try holding 1 and enter at the same time for more than 3secs
Derived from p.54 of the owners manual
Press [SETUP] to show menus
Select "Display" (6th line down or 2nd from bottom)
Select "Language" (2nd line down)
Complete owners manual @:
Thank you Mr. Ernesto half of my problem is over I have unlocked the remote of the unit, but still I am unable to switch the language of the unit to English. What should I do next ?, to convert the language of the unit to English from japanese.
Still no clue for the change of language trouble on my DVD RECORDER COMBO.
