Our Master bathroom, which is on the top floor of the house, has a toilet, sink and shower. When the water runs quickly in our sink, a strong sewer smell pours out of the drain. We have cleaned every part of the sink and pipes possible with no change. If we keep the water running a slow stream or trickle, the smell does not come up. We do not have a problem with the shower or toilet smelling, only the sink. Thanks.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
I faced the same problem few days back.
