Here is my imei 359590040125319 hope you can give me an unlock code
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: I cannot find how to change language frm swedish to english
Assuming that all the text is inSwedish and you can't understand it then follow these instructions. Using 'PANEL' button(X at bottom left) on front facia select the top left Panel (black screen with XPERIA written accross the bottom) now select windows logo(top Left)at the bottom of the list should be a 'blue circle with a question mark in the middle of it', immediatley above this should be the 'Settings' folder - select this. You should now have icons(pictures) with 3 'Tabs' along the bottom of the page - select the middle one ( this should be 'system') now look for a Globe (picture of the World) this should be 'Regional Settings' - select this. From the drop down menu select 'English' and whatever regional dialect you want, when you have done this tap top right corner, this should be OK until you are back at the Main Panel, now shut down and then restart X1, you should now have everything in English. Good luck.
SOURCE: I HAVE FORGOTTEN THE PASSWORD
I'm afraid you'll have to hard reset your device to get rid of the password request screen. Hope you have a recent backup of your personal data, to be restored afterwards, because a hard reset procedure sets your device to its factory defaults. Anyway, here it goes:
- If your device is not already in stand-by, press the power button to turn it off;
- Press and hold both left and right buttons on the front of the device (the ones right under the screen);
- Whilst keeping holding the keys, briefly press the power button to turn the device on;
- Release the keys only after a blue screen asking for confirmation comes up;
- Slide the qwerty keyboard and press 'r' (for reset).
Hope it works for you.
Cheers!
Carlos
SOURCE: i have forgoted my unlock pattern of sony ericsson
go to Imzi Communications in the Manchester Arndale Market they did mine!!!!!!!!!!!!!!
SOURCE: Repairing (replacement) Sony Ericsson XPERIA X1 LCD Display
All these videos below will help u in ur task
http://www.youtube.com/watch?v=pO2GSMb3aWM
http://www.youtube.com/watch?v=RHMKchQeOdQ
http://www.youtube.com/watch?v=V0sOaIo6724&feature=related
Pls RATE ME WELL !
