I own a smeg single oven model se335ss-5. Everything seems to still work including the grill element, fan, light etc. except there is no heat from the oven. (There is heat when the fan grill setting is selected). I believe the fan element has gone. Can anyone advise if this is correct and is there any way of testing the element before ordering a new one?
The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch.
If it is buckled, warped or has a blow hole in it, then it's faulty.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
