The heating plate on the inside of the dryer is hot. I cleaned the lint trap and the vent on the back, neither of which were clogged, but my dryer still won't dry!!!!
You will need to check all the duct work for lint buildup. This is the reason clothes won't dry or take a few cycles to dry.
my fisher and paykel GW712 washing machine had a electrical smell coming from underneath so i pulled the pump out and found it to be clear. I pulled the plastic magnetic disc off the bottom and found it to be damp so i dried it and put back together, plug it in put it on spin and it worked. The next day i filled the machine with water & clothes, the cycle started & then turned off & now i have no power to the machine. Thanks hope you can
SOURCE: not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer
is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct,
is not clogged.
Unless regular maintenance is performed, chances are there is a lot
of lint accumulated inside the dryer. This might affect the drying
time and could be a fire hazard. Make sure to have your dryer
cleaned regularly. Because this might involve taking most of the
dryer apart, it is recommended to have a qualified appliance
repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one
of them breaks down, it might affect the dryer's performance.
Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case
it would still work but will take longer time to dry the clothes.
Replace the element if found defective.
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
SOURCE: My maytag centennial dryer is getting too hot and
Exhaust problems are the only thing that will cause this. Check to make sure the exhaust behind the dryer is going straight out without alot of bends. Also no exhaust should be over 20 ft to the outside. Ther is a tip on how to clear house exhaust in the tips section. Just type dryer to long to dry and should take you there.
SOURCE: Hi, My maytag bravos dryer is one year and 2
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Testimonial: "Wow super fast response and easy to understand, thank you!"
