Have replaced the light bulb - still not working. I see three wires coming from light bulb socket and three places to connect - however, should all three be connected or is one a ground wire. I recently had a technician replace the thermostat. The light bulb was working before this repair. I am thinking a connection came loose during the repair but want to KNOW how to fix and not do something wrong. thank you
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
SOURCE: four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
SOURCE: Convert from 4-wire pigtail to
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Check the socket. Plug in the connector plug and remove the bulb. Touch the contact inside the socket. If the tester lights, the socket is good. The socket and wire running to the plug should be replaced if the tester doesn't light.
Step 2
Check the bulb with the ground wire. The bulb must be in its socket. The ground wire running to the socket should be black or brown. Stab the tester through the insulation. If the tester lights, the bulb is good. Replace the bulb if it doesn't light.
Check the ground wire. Remove some of the insulation around the ground wire. Twist one end of the extra wire around the exposed ground wire. Touch the other end to a solid piece of metal. If the brake light comes on, the ground wire is bad.
