I sent a customer for services performed and when she enters her card number it say's its an invalid card number. she tried it 4 times. still didnt work. she also tried a different card and it still didint work.
my customer cant enter HER card number on an invoice I sent to her. I would really like to get paid.my customer cant enter HER card number on an invoice I sent to her. I would really like to get paid.
You can't post conmments that contain an email address.
You need to register the card with PayPal it must be verified before use. Only cards properly added and registered to your PayPal account can only be used. Go to your account, add your card, PayPal will then carry out a transaction for a nominal account on that card, you then need to get the information from your card account as there is a reference number, which must be entered on the PayPal account in order for your card to be accepted and used for transactions.
i have a paypal account forgot my account number and password robert goldstein 215-9649950 fax 215-964-9950 email rjg-427@ comcast.net will be changing server to verizon this week best contact would be phone unless you can email me 48 hours
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2. Enter *#865625# then the 16 digit unlock code
3. Device should say: Network Lock Deactivated
4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card
Power on the handset - phone will display "phone restricted"
Select "Cancel" - phone will display "phone restriction code"
Enter the SIM Unlock code.
Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card
2) Type *#865625#UNLOCK CODE
3) Press OK
4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone;
2) The phone display: Invalid Smart Chip
3) Power on handset
4) Select "Cancel" - phone displays "phone restriction code"
5) Enter the unlock code (8 digit code*)
6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card"
2 - Power on the handset - Phone will display "Invalid SmartChip"
3 - Phone will display "Invalid SmartChip"
4 - Enter 159753#*#
5 - Enter the 8 digit SIM Unlock code
6 - Select "OK"
7 - The handset is now successfully unlocked
Model : LG CU500
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
4 - Enter the 8 digit SIM Unlock code
5 - Select "OK"
6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card"
2-Power on the handset - Phone will display "Invalid SmartChip".
3-Enter *#865625# then select option 1 and then again select 1
4-Enter the 16 digit SIM Unlock code
5-Device should say: Network Lock Deactivated
6-The handset is unlocked.
7-How to Enter Unlock Codes on CU575 (Trax)
How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#.
2-Handset shows saved, then return to startup screen
3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4-Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2-Select 'Sim Unlock' menu #
3-Enter NCK code then validate
4-Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*#
2-Shows test menu
3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4-Handset shows 'Enter NCK'
5-Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2-Enter the code
3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
If your cell phone is not listed, please follow instructions for LG C2000 above
If
If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I'm using ATT as an example.
Phones are naturally unlocked, but a service provider might lock them
When originally manufactured, all GSM cell phones are unlocked. That is, they can be used with any SIM from any cellphone service provider - always assuming, of course, that the cellphone service provider has compatible GSM service on the same frequency bands that the phone can operate on.
Most cell phone service providers electronically 'lock' the phone so that it can only be used with their service. There are obvious reasons why they choose to do this - in particular, to force you to pay what are usually very high roaming charges when you take your phone out of their network and use it elsewhere in the world.
Fortunately, this locking is reversible. With some phones, it is possible to simply enter an unlocking password code into the phone and it is immediately then unlocked. Other phones need to be connected up to a special unlocking data terminal.
Your phone has to be unlocked by the carrier. LG, Motorola, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your carrier. For example, if you have AT&T to unlock your SIM card, you can obtain your phone's PUK code from AT&T by:
● logging in to your my wireless Account online ● using their Technical Support Chat ● calling Customer Care at 1-800-331-0500
To get your phone's PUK code online from ATT:
● Log in to your my wireless Account. ● Select My Services under My Account. ● From the My Services screen, select My Phone/Device. ● Select Unblock SIM Card. ● The Unblock SIM screen will display your PUK code.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong ATT PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
There are three other ways to unlock a phone:
● The carrier will unlock the phone for you at one of its retail outlets; ● You can do it yourself by clicking on this link Free Unlock Codes , ● Pay $3.89 at the following website: www.theunlockshack.com/. I have absolutely no affiliation or relationship with The Unlock Shack or its principals.
I trust that this is helpful and solves your problem. All the best
generic because I don't know your carrier. I've used ATT as an example.
operate on.
Your phone has to be unlocked by the carrier. LG, Motorala, Sony
● logging in to your myWireless Account online
● Log in to your myWireless Account.
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I've used ATT as an example.
Your phone has to be unlocked by the carrier. LG, Motorala, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
There is a PIN locking system to lock your phone to avoid un-authorised access by others. This can be a good idea but if its entered wrong more than three times, it will result in SIM blocking. Once SIM gets blocked, phone starts asking PUK code to enter. If you again enter wrong code for three times, SIM gets completely blocked. You have to walk into your service provider outlet to get a replacement SIM card. PUK code is a SIM specific code assigned by your service provider. No way you can guess & enter it. So, when it asks for the PUK code, don't do anything, get the PUK code from your service provider. Jus call the customer care and he/she will lead you through a series of questions ( regarding the details like your email address, recent billing info, recent msgs sent ) and once you get them all correct, they will give you the PUK code.
Hi, three wrong entry of PIN code will result in SIM blocking. Once SIM gets blocked, phone starts asking PUK code to enter. If you again enter wrong code for three times, SIM gets completely blocked. You have to walk into your service provider outlet to get a replacement SIM card. PUK code is a SIM specific code assigned by your service provider. No way you can guess & enter it. So, when it asks for the PUK code, don’t do anything, get the PUK code from your service provider. Call to customer care using any other mobile phone which uses the same service provider. They will ask some details about you to make sure you are the owner of the SIM card. Questions might include your billing address, email ID, numbers you recently called or messaged etc. They might even ask you number printed on the SIM card, so be prepared with all details before calling them. Once you get the PUK code, enter it into the phone & your phone will return to normal. Good luck!!!
