We bought the machine just one month back and it stopped working suddenly. Light also not glowing.. Is there any link between light and the working of the machine? Should we replace the light?
SOURCE: Bernina 830
Pop the top open. (push up on each end with thumbs). With the top off and you watch the mechanism as you move the stitch selector up and down you will notice this moves between a forked shaped part on the right side in back that is supposed to click in place back and forth. Its very common for this to be gummed
up. Oil it and keep moving it back and forth and oil it again. It will
start clicking in and you will be in business.
SOURCE: changing light bulb on viking designer 1
when one faulty, both do not work. replace faulty one & both will then work.
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
SOURCE: Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
