Kitchen Ranges Logo
Saty Posted on Oct 14, 2012
Kenmore 790 Electric Range
I have Kenmore 790 Electric Range. Since yesterday the Left side "element on" light stays on. Both elements are cold & switches are in Off position. Please solve the problem. Thanks
Jenn
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2013
Jenn
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
751
Points
What is a F10 error code?
5 Related Answers
Anonymous
  • Posted on Apr 09, 2009
SOURCE: electric range broiler element popped and burnt
Did you replace burnt fuse/tripped breaker?
Anonymous
  • Posted on Feb 26, 2009
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Anonymous
  • Posted on Dec 30, 2009
SOURCE: i have no heat coming from the oven portion of my
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Anonymous
  • 725 Answers
  • Posted on Mar 11, 2010
SOURCE: I have a Kenmore electric ceramic top range. While
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Testimonial: "Sorry about not putting in the model number, etc. I bought a used burner switch for 10 bucks and the burner seems to be working...we'll see. Thanks "
Anonymous
  • 274 Answers
  • Posted on Jul 08, 2010
SOURCE: I have kenmore electric stove. the two large element dosen't work
try the controlls or switching the elements with the other buners.
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
The "element on' light on my Kenmore Electric Range wont turn off.
The element on indicator is typically controlled by the infinite switch (the temperature control) for the element.
On My Kenmore electric stove, the element on light will not go off. Model 790.... What should I do
Sorry to read about your problem, I hope this helps you out.
you have a defective control..either unplug or turn off ckt breaker, until you can contact a service company.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
6helpful
2answers
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
4helpful
On a sears kenmore electric range 790, my mom accidently held the time of day display off by pressing the clock button and holding for more that 15 seconds. (page 13-bottom, if you have a manual). She...
My kenmore electric range model 790 bake element don't work ,and every time I try to use it only the upper element work to preheat and it start to beeb and give me sign of( f 10) . A .A
1helpful
I hace a 2003 Kenmore Electric Ran ge #790-95682. Five minutes after turning the oven on to preheat, I heard a loud poppong noise and spark near the left side of the burner controls on the display panel....
your bake element blew look at it to see if it is broken. if it is replace. the main breaker blew in breaker box .most likely .or a wire is burnt take off back panel and look .unplug first .good luck
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
24helpful
2answers
Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
3helpful
Hot surface light indicator stays lit
The hot surface light is controlled by a part attached to the element called a limiter. For your model, the limiter is not available as a seperate item. The element/limiter assembly has to be replaced as a single unit. The top assembly, elements and limiters are all fragile parts.
If you are making this repair yourself, make sure the range is disconnected from it's power source prior to service.
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
