Health & Beauty Logo
Posted on Oct 14, 2012
I have a NOVA Weighing Scale model BGS-1212. I am not able to reset the weighing scale display. Please help
This is a simple glass weighing machine. From last 4 months i am not able to reset the scale to KG or other unit. Please help how i can reset the Digital LCD display for this machine. NOVA weighing machine BGS-1212
UPENDRA ANANT BARVE
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 03, 2014
UPENDRA ANANT BARVE
Contributor
Level 1:
Answers
Questions
0
Helped
1465
Points
0
I HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
2 Related Answers
Anonymous
  • 61 Answers
  • Posted on Mar 22, 2010
SOURCE: not sure of model of my lithium scale, it reads
change out the batteries
Anonymous
  • Posted on Jul 06, 2010
SOURCE: scale is stuck on setting for weighing in kgs and
There is no black button on the bottom or anywhere on the model mbf681dq-63
1helpful
Avery 1215 BFH 'Vintage' Shop Counter Weighing Scale
Contact Avery for a local repair facility. This is interesting!
https://www.industry.gov.au/sites/default/files/nmi/certificates-approval/6_4A_3.pdf
I remember this scale as a kid in the 1960s buying 2 ounces or a quarter pound of sweets.
https://www.google.com/search?q=Avery+1215+BFH+Weighing+Scale
Avery Weigh-Tronix
Avery Weigh-Tronix https://www.averyweigh-tronix.com Avery Weigh-Tronix is one of the world's leading suppliers of weighing scales, systems and equipment. We offer a wide range of industrial weighing systems and ...
1helpful
Why does salter scales round up when measuring grams
Because you have a scale that weighs in whole grams not parts of a gram. You need a more accurate scale like these which weigh to 1/00th of a gram (0.01 grams).
https://www.walmart.ca/en/ip/fashionhome-500g-0-01g-Weigh-Gram-Scale-Digital-Jewelry-Pocket-Scale-Backlit-Display-Tare-Function-Food-Weighing-Tool/531FGVNPN850
2answers
How to calibrate a carl liden CL-130 weighing scale
Unlikely that _you_ can. It is normally a factory feature. Depending on the use of the scale it has to be calibrated against a Government certified weight under laboratory conditions.
Contact them and ask
https://www.liden-weighing.se/en/
Support
Technical support
Tel: +46 322 442 00Mail: [email protected]
My etekcity scale is showing a C shape on the screen after weighing something - what does that mean?
A "C" will appear during the first weighing, this is a self-calibrating feature on some scales. It means the scale is re-calibrating to zero. Please re-weigh for accurate reading. Scale will also re-calibrate after every battery replacement.
Walgreens digital bathroom scales. It is weighing us 40 lighter then normal. I've changed batteries, no luck. How can I get it back to weighing us normally?
Have you tried stepping on the scale then immediately stepping off the scale allowing it to read "000" ?
This should reset your scales to read true weight!
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
[email protected]
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
26helpful
2answers
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
2answers
My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
