I keep trying to scan on my Lexmark X5650 printer, and it keep saying the scan request fail, because I need an ORC or a USB. I don't know what's neither one.
ORC is life form in the Lord of The Rings. What you want is OCR which stands for Optical Character Recognition. It is the software that converts a scanned document into a string of characters that you can edit to correct OCR errors.
To be able to scan to a computer the computer and the printer must be connected through a USB port or be part of the same network.
When you press the scan button, the printer tries to communicate with the computer and launch the scanning software installed on the computer.
Install the software that shipped with your printer, connect the computer and the printer. If everything is correctly connected and installed, the scanning software will open to receive the scanned document.
Actually, OCR text recognition is a very simple and useful tool that is used to recognize words or text on an image or given document. You can refer to what is OCR here to learn about the use and benefits of OCR text recognition and the software to perform easy and fast OCR from image or screenshot or PDF as well!
SOURCE: lexmark 3400
i had a similar problem when the printer wouldn't print. Make sure that the printer 3400 lexmark series is the default printer in the control panel. (start/control panel/printers/printers and faxes/right click lexmark 3400 series/set as default printer).
SOURCE: i have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
SOURCE: My new Lexmark X5650 doesn't scan to computer.
I had my phone turn off,but can still use my computer on line,and now my three in one printer is saying downloading application and then it say can not retrive.
SOURCE: Lexmark X5650 printer
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
