I have a 26 year old Elna Carina sewing machine, in excellent condition, which I use regularly and am the original owner. I was using a single Cam ... # 02 in it with no problem but now I am unable to remove the Cam. Can anyone give me some idea why this might have happened and how I might go about removing it?
ELNA Carina Instruction Manual
Perhaps the spindle where the cam sets needs a drop of good quality sewing machine oil, like Tri-Flow Synthetic Lube. Be sure the stitch length & width are set to Zero.
Elna Carina Electronic SU Duplex Review
How to remove can from an elna Carina Its stuck and can remove it My...
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
SOURCE: machine doesnt switch off keeps running slowly
Thanks for return email.
I took the machine to an Elna dealer who fixed the problem by by-passing the (small board) switch that returns the needle to the ready position after filling the bobbin. It is quite frustrating not having that facility after being so used to it.
Kind regards
Yolande
SOURCE: Machine Elna Supermatic 722010
I don't suppose it would be so simple as setting the wheel inside the elnagraph to "A" to engage the automatic stitches? I've done it myself once or twice LOL.
SOURCE: my Elna Carina 65 doesn't feed fabric . I've
Is it possible that you've lowered the feed dogs and not raised them again? Is the stitch length dial set to 2.5 and not on a buttonhole blue setting or the Automatic "A" setting?
SOURCE: Does anyone know of a cam to use in an Elna Carina
I am certain that we demonstrated this stitch with voile or hankerchief linen and using a wing needle and fine silk thread or rayon machine embroidery thread with the turkish hemstitch cam, cam number 140.
For the non heirloom sewers out there entredeaux looks like this.
Here is disc 140in the Elna discs sampler flyer
I am a member of the yahoo newsgroup called "Elna Heirlooms" and the following image was contributed by a member. I believe that members also list any Elna items they may wish to sell.
Or you could contact White sewing centre to order this cam if you don't already have it.
www.whitesewingcenter.com
If you find these images are just too small, feel free to email me on [email protected] and I'll send you the jpgs.
