Oh boy. here is the problem. i have also a 106240 IR/UHF receiver/transmitter that changes the channels in the satellite box from another room so i can watch them in a second tv at channel 4. the original remote for the 106240 is broken and i bought another UHF remote #153638. So i need to program the new remote to work and link with the 106240 receiver, NOT the satellite box or the tv. Is there any expert here to enlighten us how can be done ? Very simple question :how to program the remote 153638 to link with the 106240. Thank you in advance
SOURCE: I have 722 and a ir/uhf remote. Remote is set to
Hello, this is Becki Barned, with DISH Network customer service. For this issue, since you have already replaced the remote and have the 5 foot coax cable on the antenna, then at this point, we would want to send a tech out for you. The technician can determine if this is an issue with the receiver box, or can set up a back feed for you. I can help you out with this issue further. You can e-mail me at [email protected] .
Becki Barned
DISH Network Customer Service
SOURCE: DISH Network UHF/IR Remote Control: switch 21.0 remote from uhf to ir...
There is a key in the bottom that has number 2 on it . Turn the key over to number1 and slide the button under the battery cover if needed from a to b or vise versa
SOURCE: My IR remote no longer works in another room
Dawn,
If you want a remote that works via IR to control the satellite receiver you will need a IR only. The IR/UHF type only transmits signals to the receiver by UHF and the IR portion only operates the peripherals in the room such as the TV and VCR. There are some remotes that come with a kit that can change the remote to work as an IR only. I believe you have a TV2 remote and want it to work further away from the receiver particularly the room the TV is in. If this is the case you may have have to change the remote address of the new remote to match that of the old. You can do this by taking the number one remote and pressing menu-menu. Now take the new remote and press and hold the SAT button in the upper left of the remote until all lights across the top light up. Now key in the two digit number on the tv screen at remote address for tv2. Then press the pound sign and the SAT button will flash three times then press the record button and the TV2 icon should flash. Now you can cancell out of the screen on tv one and try the remote at the TV2 location. I believe this will fix your issue if not let me know. Thanks for using Fix Ya.
SOURCE: DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
SOURCE: my old Bell receiver 's
mikecrans175
I have provided the instructions on how to program your remote to your TV and addressing the remote to your receiver below. I hope this helps.
Remotes: Basic (Television Only)
Remote:
Ray Calo
DISH Network
