SOURCE: need directions to clean my tappan oven
1. Add baking soda to a cool oven.
Sprinkle a thick layer of baking soda onto the bottom of the oven. Make sure the oven is completely cool before you attempt to do this.
2. Spray the baking soda with water.
Using a spray bottle, spray the baking soda down until it is damp, not saturated. The water and baking soda together will help break down the food particles.
3. Continue spraying baking soda as it dries out.
Every few hours spray the baking soda down again to keep it moist. Continue this process over several hours, spraying water as the baking soda begins to dry out.
4. Scrape out the baking soda.
Scrape the baking soda out of the oven. Food residue will be scraped out with the baking soda.
5. Rinse the bottom of the oven out thoroughly.
Yes, you'll still have to rinse out the oven, but next time you cook your food won't have an added taste of oven cleaner.
If I had the rest of your model number I may find what Tappan now Fridgedaire Electrolux reccomends, but this is the least toxic. Have a great day..
SOURCE: tappan double oven
I have the digital timer oven and also cannot find the manual. You have to set the bake time timer, I think for 3 hours. Then you set the oven knob on clean and turn on the temp knob, probably to full but I don't think it matters. When you engage the lock, the clean light should come on/ When the oven reaches high temp, the lock light will also be on.
SOURCE: tappan tgf355 oven door won't unlock and has code f3
open the back and manually spin the motor for the latch arm it may need to be replaced
SOURCE: how does the self cleaning oven operate?
you have to find the self clean button and turn on the self clean mode. be sure to leave the house while it is in that mode. self cleaning ovens can put off dangerous carbon monoxide levels that are harmfull and can be leathel to the living beings. pets, humans.
SOURCE: self cleaning oven
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
