Sewing Machines Logo
Anonymous Posted on Oct 13, 2012
Free print manual - Bernina Activa 130
  • Anonymous Nov 03, 2012
    Activa 135 and 130 are totally different. Activa 140 is similar but Bernina does not list 130 or 140.
Tally Girl
Level 3:
  • Bernina Master 1,134 Answers
  • Posted on Oct 14, 2012
Tally Girl
Bernina Master
Level 3:
Answers
1134
Questions
0
Helped
398661
Points
2496
There are Bernina manuals as pdf's on their website, www.bernina.com, then go to Support, choose your manual in the drop down box and download it. There is not one there for the Activa 130 but the 135 is there and the 125, both will be very close to your mode.
link is http://www.bernina.com/en-AU/Support/Machines/BERNINA-activa-135
I need manual for operating janome 802
So far I haven't found a free download of the manual. The 802 wasn't listed on the Janome Manual page, https://www.janome.com/support/manuals/ , or the retired machine page (link at the bottom right of the preceding link). I did find two sites, http://www.sewingshop.com/802MANUALPDF.aspx and https://ifixmachines.com/index.php/component/hikashop/product/2406-janome-802-sewing-machine-manual that sell the manual as a PDF. If you want a hard copy, you'll have to print the manual yourself. Alternatively, take the PDF on a USB drive to a print shop (Kinkos, UPS store) and pay them to print it for you.
I hope this helps.
I have been given a Singer Simple model 3116, but I need a manual. Can't print out at this time. Will you send me one? Carol Stevens 534 south walnut st. Nowata, OK 74048
Hello, Carol -
The public library located near you.probably has computers connected to the Internet which you can sign up to use, along with printers which you can use to print the Singer 3116 manual for which I will give you the link.
Note: For prints made at your local public library, you will need to pay the cost of printing (cost per page - probably 10 cents or more per page.) The manual has 94 pages.
This is the link where you can download the manual f(PDF format, requiring Adobe Reader software - free) for free:
http://www.singerco.com/uploads/download/438_3116.pdf
After downloading the manual be sure to save it to your Documents folder using a file name you can find easily - maybe: Singer 3116 Manual.
If you choose to print all or part of the manual at the public library, save the file to a USB drive which you can take to the library. Someone on the library staff will be able to demonstrate how to print all or some of the pages of the manual from your USB drive. Note:
If you do that, be sure to close the USB drive before removing it from the library computer or you can damage the portable drive and lose the file saved on it.
Best wishes.
How do I print the free manual?
I have to assume that this manual you are wanting to print is a manual for a sewing machine that you've had for years or perhaps you just purchased it and the only information that came with it was a sheet that said "for a complete printable copy of the owner's manual/operating instructions" go to:[email protected]" or something similar, is that a fair guess? Well, even if it's not a sewing machine manual and you don't have any information pointing you to a user friendly website, have no fear, Google is here! I'm going to assume that you are at least somewhat familiar with computers and have some knowledge of how to search for or go to websites on the computer because you obviously found your way to this website and even figured out how to post a question. Not necessarily spelled out in blazingly obvious step-by-step instructions, I might ad! Anyway, if you did have a web address that directed you to this online document or "manual", then that's half the battle. Many free online instructions are uploaded to the internet in PDF format and it's probably a safe bet that your free manual is no exception to the rule, however some PDF documents are delivered to the web page all tied up nice and neat with a toolbar at the top of the first page like you would expect, thus it appears that there's no print command or printer icon anywhere which would lead you to believe that the document is certainly free and free for you to access, but why would they say it's printable if there's no print option showing here, right? Well you can use your keyboard to start the printing process. The print command on your keyboard is executed by pressing and holding down the key labeled Cntrl (bottom left on the keyboard) while at the same time you press the letter P key. Once you've pressed the P you can release both keys and in a few seconds the print command window should open up allowing you to choose/verify that all of the print "options" are set the way they should be. Verify that the "destination" shows as a known printer that belongs to you and is near your computer. Then take note of the number of pages in this document and make sure to have enough paper loaded in the printer and the printer is powered on. You can choose to print "All" pages or you can select the 2nd radio button and type in the page numbers that you want to print. For example if you want to print page 2, 3, 4 and 5 you would type 2-5 in the space provided. If you want to print 1, 3, 5, and 7 you would type 1, 3, 5, 7 and then click on the print button. If you are starting from scratch and don't know where to find the online manual (ie: there was no web address included or the machine is old and you only heard about a "free manual" from someone who mentioned that there should be a free manual, then that's where Google Search comes in. I have had really good luck finding manuals and or parts lists or schematics or even step-by-step how-to instructions (with pictures even) simply by typing in the Google search window something like "free printable owners manual for a Singer model S6372 sewing machine" which nearly always generates a page with dozens of options or "links" that lead to a PDF document that contains the entire manual free for me to print (or not) at my discretion. The only issue that I've ever had (and its not much of an issue if you know your keyboard commands) is that not all of these PDF documents have a toolbar at the top of the window that allows for easy execution of the printing. It can also make it difficult to save a document to your computer if you'd rather not print because there are too many pages. In that case you might want to learn to execute the copy and paste keyboard commands and copy the entire manual into a new blank word document. But that 's a lesson for another day. I hope I didn't insult you by assuming that you had no knowledge of the printing process, if this was too much information then I apologize, but I didn't want to make the wrong assumption either so I chose to give the most complete, clear and concise step-by-step instructions I could. I hope this was helpful. If you have more questions or just need me to clarify something please post another question or you can email me at [email protected] and I can try to answer your questions directly. Or if you are so enclined, you can always "Ask Google!" He knows everything! Lol!
1helpful
Has anyone got a users manual for a singer 3827 sewing machine
Normally you could find a free download online at Singer, but this one only has the manual in print form $15.
How old is the machine?
2helpful
I would like to find a printed manual
There's a free to download manual available on the Singer site. It looks like you manual is out of print though.
http://www.singerco.com/accessories/manuals.html
Just type in 1934 and click on search.
Then click on free download!
I saved files like these for my manual onto a USB pendrive (you could burn a CD) and took them to work to print out and bind myself. Hope this helps!
5helpful
Lost the manual,where can i get the manual for free?
Go to this page on Singerco.com and you'll see a $15 item and a free - $15 is for a printed manual, the free is for a PDF download you can view on screen or print to paper.
If it asks for the model just put the 7436 in the box.
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
