SOURCE: Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If
for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: kitchenaid microwave makes a loud noise and does
try these
pls rate my suggestion..
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
llllllllllll'l
