SOURCE: Cannot start my Comet pressure washer...water runs
Hi: Some things to check: Is the gas old or contaminated with water. Change it if you are unsure. Are you getting a spark? To check this: BE CAREFUL. Remove the plug. Plug it back into its wire. Hold it WITH INSULATED PLIERS so the tip is close to the metal frame of the machine and have someone pull the starter cord. The plug should spark.
SOURCE: Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
SOURCE: no high power water pressure coming out
You should dismantle and clean the manifold from the pump , it is sticking. Common
