All led lights on control panel flash rapidly. the chair will recline but it will not drive. the emergency brakes are in proper position. i just cant seem to find the problem
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
SOURCE: elctric wheelchair, flashing rapidly the error display
Have the batteries load tested and be sure that the chair is in gear.
SOURCE: acs typh. invacare electric wheelchair, red light
Press the power button on then press the horn button twice before ten seconds. this should unlock the joystick
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
SOURCE: Invacare power chair model #1089384;
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
