Electrolux EWDW6505GS Fully Integrated Dishwasher with 9 Wash Cycles, Nylon Racks, Wave-Touch Contro... 24 in. Built-in Dishwasher Logo
Carla Posted on Oct 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does this dishwasher have a lock button?
The control panel seems to be locked, it will not start cycle. Wash cycles work.though
  • Official Brand Answer 4,342 Answers
  • Posted on Oct 17, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467816
Points
5907
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
  • Linda Rigger
    Linda Rigger Jun 24, 2014
    I always use the child lock on my dishwasher when not in use and for some reason it won't come on anymore...even when holding down the DELAY TIME icon. Any suggestions?
  • Linda Rigger
    My model is EWDW6505G S/W/B
5 Related Answers
A
Anonymous
  • Posted on Jun 11, 2007
SOURCE: Dishlex dishwasher
I have the same problem and the main conrol board was replaced. No Problems since.
Anonymous
  • Posted on Nov 26, 2009
SOURCE: I have an electrolux edw5505eps dishwasher. The
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 04, 2009
SOURCE: frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Anonymous
  • 269 Answers
  • Posted on May 18, 2010
SOURCE: EDW5505EPS Electrolux Dishwasher. One cycle light
Have you tried holding the cancel button down for about 15 seconds as these units can sometimes get stuck in a cycle. Try this anyway first.
Hope I helped.
Ambari
  • 901 Answers
  • Posted on May 24, 2010
SOURCE: cannot program a cycle at all,
Contact the service provider. It could be pad problem or other circuit problem.
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
2helpful
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
How do you control dd605i dishwasher when touch controls do not work? My wife saw the service man control the top panel using the front buttons.
This will only control the diagnostic service mode, it will not run a regular wash cycle.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
GE GDWT160R dishwasher.
Some type of dirt or dust got in your panel, now the contacts don't touch. Not a diy job.
Kenmore ultra wash dishwasher has lock-on feature won't turn off
Hold the control lock in for more than four seconds. See if that works.
My website
s?a b?p t? t?i nh?
3helpful
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Control panel button that reads 3 sec will not shut off - I can't start my normal cycle to wash the dishes -- Serial #10376756ws - model #mdb7100aww
Push and hold that button till it goes off,supposed to be 3 seconds but seems to take 5 or more,someone locked the controls..
Aug 24, 2009 • Dishwashers
2helpful
2answers
None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
Dishwasher "lock on ' control wont turn off
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
