Why did black tank water come up in my shower
There is a "sacrificial anode" inside of a hot water tank, electric or gas-fired. Its purpose is to corrode at a high rate, in order to protect the rest of the heater from corrosion,
All hot water tanks (save the plastic ones)corrode. It is a given,
The sacrificial anode is usually made of zinc, or a zinc/copper/other alloy. When it gets eaten away from electrolysis (the action of minerals in the water, and the metals components of the hot water tank/heating elements/etc make the entire unit operate as a small battery), it usually turns a nasty, crumbly black.
It will leach into the water, and if enough chunks fall off the anode, it will color the water as you describe.
The SOLUTION, to "FixYa", is to write down the model number of your hot water tank, go to the local Home Improvement store (or Amazon.com) and order a new anode. Replacing it is pretty straight-forward: turn off the water, turn off the heater, drain the tank down a bit from a faucet that is lower than the top of the tank (or the valve at the bottom of the tank) , remove and replace the old anode with the new one (it screws into the top of the tank, and is a large-headed "bolt", maybe an inch-and-a-quarter across).
Now that I have written this tremendous missive, I re-read your question/problem and see I missed the mark.
You have "black water" backing up into your shower.
You've plugged your sewer line a bit. Quit using so much toilet paper, you have a near-stoppage of your line. Pour a bottle of Liquid Plumber (or two) down the shower floor drain, let it sit for a number of hours, and then run hot water down the drain at as fast a rate as you can before it starts backing up to clear the clog.
Your use of the term "black water" makes me think you might be in a RV (Recreational Vehicle) or the like, so your problem may be cold-weather related. A heat-gun or hair-dryer ran along the drain lines (or a big heater aimed under the RV for a while) might unfreeze the clog and allow it to pass into the holding tank or sewer line.
Your "Black Water Tank" may simply need to be emptied, too.
Flush more often (important!), use less paper in each flush, eat less beans, and try to p**p in the RV public restrooms more.
Even so, if your are in an RV, the sacrificial anode in your hot water tank is good for only two years, tops, before it fails and your very expensive hot-water tank starts to leak. Fix it anyway.
