Need to find how to find pump and check for clogs.
Hi - I understand you will like to know where to find pump and check for clogs. Try the following steps below and hope it is helpful: To completely clear any clogs in the washing machine drain you will use a pipe auger (snake). Start at the roof plumbing vent and drop cable to roughly 10 or 15 feet past the actual drain. If there is a clog present, the snake will bring up a chunk of debris. Remove it from the top of the vent and discard. The drain hose is visible toward the bottom of this washing machine. It is held in place by a clamp or a couple of screws. Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws. When a drain backup occurs, pieces of debris can lodge in the hose, causing clogs and odors. Soak the hose in a bucket of warm bleach water. Soak the drain hose in a bucket of warm water mixed with 1 cup of bleach. Look to see if the line is free of obstructions. Run a small length of clothes hanger through the hose to clear any hard debris. Reattach drain hose and connect to drain pipe. Reattach the drain hose using a screwdriver or pliers. Insert the hose into the washing machine drain. Be sure it is all the way into the drain opening. Run the washer through a full cycle with 2 cups of bleach added. Cycle the washer with warm water and 2 cups of bleach. The bleach will help remove any odor-causing particles in the machine and drain hose. Running the washing machine through a cycle will help flush away any remnants of the drain pipe clog.
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
Hi
This draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Daniel
Hi
Dishwasher not
draining issue usually occurs due to kinked drain pipe, clogged drain filter or
drain pump. Check the drain hose for any visible clogging, remove if present.
If no visible lint is present then remove then turn off the dishwasher and remove
the drain hose and check for any visible clogging. If still not visible then
the drain filter or drain pump is clogged and you'll need to clean the drain
filter and drain pump. Also, check for any food pieces stuck near the pump
impeller.
Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat.
Hope this helps...
Daniel
