Freezer runs all the time . checked gaskets on door their clean and tight tried to turn off freezer by pressing down arrow till 0 appears in window thats when e7 appears.Any help would be great.
SOURCE: Freezer Not Cooling
Sounds like the low pressure cutout switch is stopping your compressor running, especially if the "5 seconds" you mention are exactly the same length each time. Not enough refrigerant would be the usual cause, but the reason for the refrigerant loss is harder to tie down - possibly a seal or a loose valve seat or even a pinhole in a copper tube. Best solution now would be to get a refrigerator mechanic to top it up and check for leaks - get a quote first to check - 'fridge gas is getting costly. Other possible solution is that the low pressure switch itself is faulty, relatively inexpensive to replace (but unfortunately you will need at least a partial gas recharge on most types of system after) - your fridge gas guy will be able to check very easily if there is adequate gas in the system, and should check this low pressure switch if there is not. Usually this is fixable many times, just check the cost first. Hope this helps :)
SOURCE: Frigidaire Chest Freezer Door Insulation smells like fish
might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
SOURCE: freezer door is accumulating frost inside it at
The gasket is not sealing correctly and is allowing warm air to meet cold air just below the seal.
Get someone with more skill to fit a new gasket , preferably one made by the original manufacturer , which should fit unlike some of the parts made by third party suppliers
SOURCE: I have 16.7 upright Frigidaire Ultrafreeze
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Testimonial: "This advice seems really clear-- and I will get help from my hubby to implement it. Thanks a lot for your help! Anne"
SOURCE: Door alarm light is on
The open door alarm is triggered by the small switch that also triggers the internal lighting. This is easy to test: open the door and press the switch - on a normal one the light should go off.
This is the switch
http://www.bizrate.com/refrigerator-accessories/oid1852839097.html
And here is in the parts manual page 4 part 14
ftp://ftp.electrolux-na.com/prodinfo_pdf/stcloud/5995552030.pdf
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Hi - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
