When i go the the settings section on the computer control pad of the leapster handheld, then to the section where 'repair' 'reset' are listed but they are grey and non-active buttons not green so i cannot click on them. any tips? problem is that the handheld wnats to be connected to the PC but when i do it does a tune up then fails saying the handheld ahs been disconnected, i thought a repair might work?
SOURCE: leapster learning handheld game
How do i get the screen to operate again. The audio functions well but no picture.
Harper
SOURCE: didj "Download in Progress Do Not Disconnect" (DiPDND)stays on
well you are not alone
i think that all the parents thats bought this cute game
got suckered
because i have the same problem too
its a problem with these games
and i will never buy another product that have to be tuned
at all
there are problems with these games
i do not urge any parent to purchase a diji (STAY AWAY )
SOURCE: I have just brought a
You need to re-connect your Leapster 2 to your PC. You have to make sure that the software is already updated both in the PC and in the console. Try to uninstall and re-install the LeapFrog Connect and wait until the software has been configured and update automatically which is until you see the status in LeapFrog Connect screen is "connected". You need to wait at least 10-20 mins for it to be completed I'm afraid.
One more thing, make sure you get the latest LeapFrog Connect Software from LeapFrog website instead of installing it from the supplied CD.
BTW, you can get more downloadable games for your Leapster 2 here:
leapster-2.blogspot.com
SOURCE: I turn on my daughter's
You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog
Connect, you can also get more downloadable games for your Leapster 2.
You can get it here:
SOURCE: My son's Leapster Explorer suddenly
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
This will give you the PARENT SETTINGS menu.
You will need to start them from scratch to choose a new pet. It is sad but at current it is the only way to choose a new pet.
