Zebra Z6M Plus Thermal Label Printer Logo
dant87 Posted on Dec 27, 2017
Zebra Z6m Error Paper Out
I have a problem with a Zebra Z6M Printer. It will try and print a label but then stop after 2cm and say the paper is out. Error Condition Paper Out I then open up the printer and open and close the print head and the error is cleared. Then unpause the printer and does the same thing. Anyone any ideas? Thanks
1helpful
Z6m won't stop feeding
I would venture a guess that the sensor that detects the labels isn't working well - it's supposed to see the difference between label and backing paper and stop at the correct position.
Zebra Z6M Plus no startup
here you go http://www.zebra.com/us/en/support-downloads/industrial/z6m-plus.html
Why would bar code print both vertically and
This is I think due to the data being sent to your printer. On a Z4m the width is 4 inch and whatever is beyond is not printed. On your Z6M the coordinates are valid so your printer will print the code.
Same Problem with Z6M
Your Logic bd needs to be replaced or repaired.
Rory
Midrange Repair and Parts
My printer won't print. It will only produce blank pages.
Usually that means that the labels are missing from the printer. Turn the printer off. Reload the label stock and restart the computer it is connected to. Then it should work properly.
1helpful
Z4m zebra printer problem
Might foul the ribbon sensor, clean the sensor and try to print again.
3helpful
3answers
Printing error condition
First clean the sensor tag and sensor head open and tape. Then perform a calibration label pressing the PAUSE and FEED buttons and turn on the printer, release the keys until it starts to move the label. Wait until you are finished and ready to print.
2answers
Thermal Printer Problem
We use Nice Labels software in house and it uses the standard windows printer drivers. A good alternate site for printer drivers is seagullscientific.com.
Any further driver probs, contact me at www.lancerlabels.co.uk
trevor
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
