SOURCE: GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
SOURCE: Three year old Whirlpool Refigerator (ED5FHEXNB),
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
SOURCE: top of water filter broken off
use a pair of plyers in you can grab it on the outside if it's in the inside get a small pair of vive grips and try to get a bite on the plastic and turn it couter clock wise to remove.
SOURCE: Keurig states Ready to Brew, but it just spits
This same thing happened to me yesterday. I would start to brew, a teaspoon of water would come out, then nothing. I didn't descale because the pump wasn't pulling water. After calling Keurig, I decided to mess around with my machine since a new one was on the way. Check the intake valve where the reservior hooks up. I noticed some standing water in mine, so I spent 30 minutes siphoning it out with a twisted paper towel. I didn't think it would work- but it did! Back to full functioning, at least for now. Keep siphoning until the towel end comes out completely dry.
