Http://www.laptop-dvd-drivers.com/asus-m3n-laptop-motherboard-p-1549.html
Click on the left view, use your mouse cursor, and magnify the black object. (Maxell)
It has a Red wire, and a Black wire ending in a small White plug.
The black object is just a type of plastic bag, essentially. There is a CR2032 battery inside it. The small white plug coming from the battery's wires plugs into the motherboard.
The Left view is a view of the Bottom. The RTC battery is on the bottom of the motherboard.
So is the Processor.
[RTC = Real Time Clock. Newer nomenclature for the CMOS battery]
Another view of the RTC Battery,
http://www.pchub.com/uph/model/0--10040-3/M3000N-M3N--parts.html?ps=20&type=0
Bottom of page. (Maxell CR2032WK)
No exact Service Manual. Use the following info to disassemble the laptop with. USE an ESD wrist strap, and connect it's alligator clip to a good ground source. Or you can use the laptop for an expensive paperweight.
Regards,
joecoolvette
1) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-asus
2) http://www.insidemylaptop.com/category/2-asus-laptops/
SOURCE: where to find the cmos battery
Toshiba made it hard to get to this battery. You will have to remove the entire motherboard and it is in the bottom corner, soldered to the board. I just went through this for a friends computer, it was not fun.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If this post has helped you, please help me, and rate this suggestion with the highest FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
SOURCE: hi hello pls help me to restore cmos bios setting
hi hi have a asus m3000n that wont recanize dvd drive can any one help with this problem thanks
