7 beeps on boot ONLY Black screen
These are the Dell beep codes.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
SOURCE: My dell inspiron mini 1012
Its a POST Beep code:
For more info, go here:
http://support.dell.com/support/edocs/systems/opgx620/en/ug/tools00.htm#wp1120374
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
SOURCE: my inspiron mini 1011 producing
Thaat isknown as a beep code.
Does your system start up normally?
If not let me know how many beeps and I can let you know what it meens.
SOURCE: Dell Inspiron 700m won't start
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Testimonial: "leecom72, Thank you for the prompt advice. I tried it cleaning it, but still not working. I'll try new memory (wanted to upgrade anyways). Thanks!"
SOURCE: Dell Inspiron 1545 Booting Problem [Black Screen].
Insert the original Windows CD-ROM into the DVD-drive, and see if the computer will "boot" from that disk. If so, then it could be your 'C:' drive which is having the problem, and thus not "booting" your computer from it.
I have a Dell inspiron 17r and ran the test and at the end the beeps go 1 beep 4 beeps 2 beeps? error code is 2000-0142
