Netopia Cayman 3347W-Ent Wireless Router Logo
johnsmith Posted on Oct 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is not secured anymore
Techgees
Level 2:
  • Expert 78 Answers
  • Posted on Oct 11, 2012
Techgees
Expert
Level 2:
Answers
78
Questions
0
Helped
327850
Points
111
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
4 Related Answers
Anonymous
  • 155 Answers
  • Posted on Aug 07, 2008
SOURCE: Netopia 3347W
did you reset or restart if reset all the info has to be re inputted also if you have isp like bellsouth or at&t they will change pass if the router resets i know this from past troubles with mine but after i stopped resetting and just restarted i was fine lol
miro212
  • 13 Answers
  • Posted on Feb 11, 2009
SOURCE: bought used modem and don t have user name and passord
on the back panel you will find reset button. press and hold for 20sec. So your router will get back defaul settings.
Anonymous
  • 29 Answers
  • Posted on Mar 28, 2010
SOURCE: I have a Cayman 3347w wireless router and I am
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Azrael SRL
  • 11800 Answers
  • Posted on Aug 10, 2011
SOURCE: was given an older netopia 3347-02-1006L "type
Reset it again as explained here
http://www.netopia.com/support/hardware/technotes/CQG_102.html
If necessary do it using the serial connection.
If it behaves the same then the router firmware has been corrupted and the only way to save this router is to reload the firmware by using the serial connector - a special bootloader will have to be used. You must request for it specifically from them. Use this form to get registered
http://www.netopia.com/support/hardware/firmware/updates.html?3347-02-1006dl
and then request it.
Driver download
Wireless routers don't need drivers. Maybe your wireless adapter needs drivers.
What is the user name ?
I searched the user manual, and it does not specify. Try leavng it blank or try Admin.
If it was bought used, it may have old old info in it preventing your access.
Use the recessed reset button next to the power input to restore to factory settings. Hold for about 10 seconds then power off then on.
The red light under "internet" is on instead of green. We show connected on our pc, but when we try to connect to the internet we cannot get a connection?
Turn the router off, unplug it completely for 10 - 15 mins, then replug and turn on. If the problem is still present, press the reset button (small small hole, may require a needle) for 5 - 10 seconds if needed then follow the first step.
Att dsl cable with wirelesss router netopia 3347w
yes it will work but you will need to login to the router interface and reset the router configurations
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
1helpful
2answers
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Can't find wep key
With each new router comes a new WEP KEY by default this could be found normally on the back of the router/access point near the bar code it should have something like this:
SSID: XXXXXXXX WEP KEY: XXXXXXX
If you don't find this sticker or don't have it just reset the router or connect by cable go to the web interface and copy or change the WEP Key there defined.
Hope that helps.
If you need and advice about a new wi-fi router....linksys all the way...;)
Netopia 3347 moved to a different location/tel number
If you got the netopia in anyone of the 13 states that ATT controls, then that netopia will work in any other state, not just the phone number it was attached to. We are implementing technology now that it will be phone specific, but most people dont have that installed yet.
All you have to do is reset the netopia, open a browser, type 192.168.1.254 and set it up with the new username and password you created when you got your new DSL service.
spin
Bought used modem and don t have user name and passord
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Top Netopia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
