I have recently just changed the battery and alternator. there was some shaking at 50mph and above but it would go away. I assumed it was from a needed wheel alignment.
SOURCE: need fuse box location in 1997 BMW 740IL
The fuse bos should be int he back left of the trunk under the carpet on the side. Peel back the carpet from the side...slowly and you should find it there.
SOURCE: 2000 bmw 323i-shakes and clanking
hey man, i had the same problem with my 325i (clankins sound on cold start-up) i took it to the dealership to have a look they diagnosed it wrong telling me a pulley is cracked and quoted me a ridiculous amount to fix it so, i decided to have a look 4 myself and i found that a pulley was loose the pulley looks similar to that of a cog of a bike it has 1 bolt in the center, that bolt was loose so all i did was tighten it and it solved the clanking sound , give it a shot it might work for you.
SOURCE: 1994 BMW 740il - Doors will not unlock, battery is dead
try this, put the key in the drivers side door then turn the key to open position as th same time lift up the door handle . if this does not work then jack up the car , and with jumper cables hooked them to the starter--red to solinod of starter and the ground to any good ground.then hook the other end to another vehicle.keep in mind all the safety precautions!Then try the door with the key in normal operation.Your battwery is dead.!
SOURCE: how to add transmission fluid to 2000 bmw 740il
Hey
They don't put a fill tube on them . It's suppose to be life time fluid. Must be filled from the fill hole and the plug is on the right rear side of the trans.
Hope this has helped
