Question about Precor Exercise & Fitness
Hola Ernesto, congratulation for your seccess,, thanks for the great support you had provideded to the community. I own a precor C934 have lower Controller, LPCA problem, and I would like to check if
The machine is showing error 22 code: Error 22 - No Motor Pulses at Start Up. Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started. Checked the brushes are ok, speed sensor ok, checked the lower control board and it has missed the 15V measuring point is showing -172V, the 5V shown 1.2V and 18V shown after I touch a pin #4 of a 6 pin IC (no print to identify model) the LED lit up and 5V and 17V normalized, but not 15V still remained showing the same ( -172V). I'm thinking they may be a problem with a voltage regulator but I have not identified yet, so if you have the blue print for the board and any idea what can be the problem, please let me know. Thank you Luis loglez@gmail.com
    Top Expert:
  • Precor Master
  • 12,223 Answers
Thank you brother.
That causes can be
1) optical infrared speed sensor is obstructed.
2) drive motor brusher are bad.
3) speed sensor position is incorrect
4) speed sensor potentiometer adjustment is incorrect
5) speed sensor is faulty.
6) lower PCA is bad
7) lower PCA to upper PCA interconnect cable is bad
8) upper PCA is bad
Remedies: vacuum the drive motor pay attention to speed sensor .
b) motor brusher do not make suffciente contact repair
c) adjust the speed sensor see the scheme attached.
d) locate the speed sensor potentiomente on the lower PCA.set the potentiometer in mid-range
e)measure voltage D.C. for 5vdc, two fo the leads will toggle between 0vdc-5 Vdc.as you rote the speed sensor.
f) substitute a known good lower PCS for determine g) substitute a known good interconnect cable h) substitute a known good upper PCA for determine if is faulty.
God bless you
see the block diagram and my personal TIPS for motor in treadmills
Hola Ernesto, congratulation for your seccess,, th - 10_12_2012_10_06_23_am.gif
Posted on Oct 12, 2012
SOURCE:
bwinton
  • 83 Answers
SOURCE: No motor output to drive the belt
Sounds like that there is a short in the control board.
Posted on Mar 24, 2010
outfield502
  • 79 Answers
SOURCE: my treadmill motor starts exactly
that a qualified technician check the motor controller board the mosfet (IRF250N.) or diodes
Posted on Sep 08, 2010
outfield502
  • 79 Answers
SOURCE: I have a problem with
just change the Diodes D4015L and SCR´s S4015L whit a caugting buy the new change and ready or is a MC-2100 w / transformer just change the MOSFET IRF250N
Posted on Sep 11, 2010
Joed911
  • 4338 Answers
SOURCE: when you push the start
Unplug treadmill from wall outlet. Wait 60 seconds, allowing lower board to discharge built up energy.
Then reseat the 12 pin connector.
I had same issue, but mine was under warranty and they sent me a board. Have you tried a calibration?
http://www.horizonfitness.com/uploadedFiles/Customer_Support/Horizon_Fitness/Troubleshooting/Treadmill/Universal_Calibration_Instructions.pdf
Call T/S, good techs there.
Horizon Fitness Tech Support a call, toll free, at 1-800-244-4192. We're open Monday through Friday, 8:00 am to 5:00 pm Central Time
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 21, 2011
  • 1456 Answers
SOURCE: my life fitness 93t is
Hello
The common cause of the startup error is the Opto Sensor (Speed Sensor),either there is a poor connection of the opto (speed) sensor or it is out of adjustment or bad.
Check the opto (speed) sensor connection and wires. Make sure the opto (speed) sensor is evenly spaced over its disk. Replace if you find any broken or damaged wires. Inspect cable and connection of opto (speed) sensor. Repair and replace damaged cable or connection of the opto(speed) sensor.
Inspect alignment of opto (speed) sensor. Sensor should be centered evenly over target. Adjust or replace opto (speed) sensor if necessary
Your sensor might look ok but you have to inspect it very carefully.
Posted on May 05, 2011
Precor 9.41 si error code 22
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PC
Apr 20, 2014 | Precor 9.41 si Walking Belt
Error 22 on precor 9.41si treadmill. How do I vacuum the speed sensor. Where is it located?
Model: All Models
Recommended Action:
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Feb 20, 2014 | Washing Machines
Precore m9.43 treadmill error 22
Model: All Models
Recommended Action:
Feb 05, 2013 | Precor 9.21 Treadmill
Model: All Models
Recommended Action:
Belt stopped and showed message ERR22
Model: All Models
Recommended Action:
Dec 06, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Error 22 keeps showing in my precor treadmill
Model: All Models
Recommended Action:
Sep 12, 2012 | Precor C954i Commercial Treadmill
Precor 9.35 Problem--Please Help!
Model: All Models
Recommended Action:
Jul 21, 2012 | Precor 9.35 Treadmill
Hi, I have a precor 9.21i treadmill. The machine will start for about 3 or 4 seconds and then gives me an error code of 22. I am a major appliance tech, but I know little of treadmills. I was guessing...
Model: All Models
Recommended Action:
Aug 02, 2011 | Precor 9.21 Treadmill
My Precor 9.31 made a loud "click" sound and turned off while I was walking on it. Error 22. What does this mean?
1. Drive motor brushes are bad or the lower PCA is bad.
Apr 15, 2010 | Precor 9.31 Treadmill
What does code 22 mean?
Description
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Jan 18, 2010 | Precor 9.21 Treadmill
Exercise & Fitness Logo
146 people viewed this question
Top Precor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Rick Hickerson
Rick Hickerson
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
