Google Chrome Logo
Ainsley Barrett Posted on Oct 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My google chrome crashed and everytime i click on it a message says DEP has closed it
I tried the method where you go into the settings and select "Turn on DEP for all programs and services except those i select" and it simply says DEP cannot be enabled for google chrome, please help.
Anonymous
Level 2:
Sniper:
  • Expert 162 Answers
  • Posted on Oct 19, 2012
Anonymous
Expert
Level 2:
Sniper:
Answers
162
Questions
0
Helped
51617
Points
408
To use hardware-enforced DEP, you must meet all the following conditions:
  1. The computer's processor must support hardware-enforced DEP.
    Many recent processors support hardware-enforced DEP. Both Advanced Micro Devices (AMD) and Intel Corporation have defined and shipped Windows-compatible architectures that are compatible with DEP. This processor support may be known as NX (no-execute) or XD (execute disable) technology. To determine whether your computer's processor supports hardware-enforced DEP, contact the manufacturer of your computer.
  2. Hardware-enforced DEP must be enabled in the BIOS.
    On some computers, you can disable processor support for hardware-enforced DEP in the BIOS. You must not disable this support. Depending on your computer manufacturer, the option to disable this support may be labeled "Data Execution Prevention," "XD," "Execute Disable," or "NX."
  3. The computer must have Windows XP with Service Pack 2 or Windows Server 2003 with Service Pack 1 installed.
    Note Both 32-bit versions and 64-bit versions of Windows support hardware-enforced DEP. Windows XP Media Center Edition 2005 and Microsoft Windows XP Tablet PC Edition 2005 include all the features and components of Windows XP SP2.
  4. Hardware-enforced DEP must be enabled for programs on the computer.
    In 64-bit versions of Windows, hardware-enforced DEP is always enabled for 64-bit native programs. However, depending on your configuration, hardware-enforced DEP may be disabled for 32-bit programs.
For more information about DEP, about DEP configuration, and for a list of Windows Operating Systems that support hardware DEP, click the following article number to view the article in the Microsoft Knowledge Base:875352 A detailed description of the Data Execution Prevention (DEP) feature in Windows XP Service Pack 2, Windows XP Tablet PC Edition 2005, and Windows Server 2003For information about how to configure memory protection in Windows XP with Service Pack 2, visit the following Microsoft Web site:
http://technet.microsoft.com/en-us/library/cc700810.aspx
To confirm that hardware DEP is working in WindowsTo confirm that hardware DEP is working in Windows, use one of the following methods.Method 1: Use the Wmic command-line toolYou can use the Wmic command-line tool to examine the DEP settings. To determine whether hardware-enforced DEP is available, follow these steps:
  1. Click Start, click Run, type cmd in the Open box, and then click OK.
  2. At the command prompt, type the following command, and then press ENTER:wmic OS Get DataExecutionPrevention_AvailableIf the output is "TRUE," hardware-enforced DEP is available.
To determine the current DEP support policy, follow these steps.
  2. At the command prompt, type the following command, and then press ENTER:wmic OS Get DataExecutionPrevention_SupportPolicyThe value returned will be 0, 1, 2 or 3. This value corresponds to one of the DEP support policies that are described in the following table.
DataExecutionPrevention_SupportPolicy property valuePolicy LevelDescription2OptIn (default configuration)Only Windows system components and services have DEP applied3OptOutDEP is enabled for all processes. Administrators can manually create a list of specific applications which do not have DEP applied1AlwaysOnDEP is enabled for all processes0AlwaysOffDEP is not enabled for any processesNote To verify that Windows is running with hardware DEP enabled, examine the DataExecutionPrevention_Driversproperty of the Win32_OperatingSystem class. In some system configurations, hardware DEP may be disabled by using the /nopae or /execute switches in the Boot.ini file. To examine this property, type the following command at a command prompt:wmic OS Get DataExecutionPrevention_DriversMethod 2: Use the graphical user interfaceTo use the graphical user interface to determine whether DEP is available, follow these steps:
  1. Click Start, click Run, type wbemtest in the Open box, and then click OK.
  2. In the Windows Management Instrumentation Tester dialog box, click Connect.
  3. In the box at the top of the Connect dialog box, type root\cimv2, and then click Connect.
  4. Click Enum Instances.
  5. In the Class Info dialog box, type Win32_OperatingSystem in the Enter superclass name box, and then click OK.
  6. In the Query Result dialog box, double-click the top item.
    Note This item starts with "Win32_OperatingSystem.Name=Microsoft..."
  7. In the Object editor dialog box, locate the DataExecutionPrevention_Available property in the Properties area.
  8. Double-click DataExecutionPrevention_Available.
  9. In the Property Editor dialog box, note the value in the Value box.
If the value is TRUE, hardware DEP is available.Notes
  • To determine the mode in which DEP is running, examine the DataExecutionPrevention_SupportPolicy property of the Win32_OperatingSystem class. The table at the end of Method 1 describes each support policy value.
  • To verify that hardware DEP is enabled in Windows, examine the DataExecutionPrevention_Drivers property of the Win32_OperatingSystem class. In some system configurations, hardware DEP may be disabled by using the/nopae or /execute switches in the Boot.ini file.
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Feb 01, 2009
SOURCE: uninstalled google chrome and now yahoo messenger icons dont work
I can solve your problem, just follo these steps:
  1. In Vista --> "Control Panel"(In Classic View) --> "Default programs" --> "Set Associations".
  2. Scroll down until u see the header called "Protocols"
  3. under Protocols, there highlight "HTTP" and click Change program.
  4. Now select your Fav. Browser.
Your problem is solved. If you still unable to do it,I'll help you in detailed.
Axekick
  • 49 Answers
SOURCE: i didn't like google chrome
I've never used Google Chrome but believe if you uninstall Yahoo Messenger. Then re-download and reinstall it(Yahoo Messenger) that it should remedy your problem since Google Chrome is now removed.
Anonymous
  • 5158 Answers
  • Posted on Mar 08, 2009
SOURCE: google chrome i cant uninstall
hit control ault delete.... select task manager, click on the processes tab and look for any examples of google running. end them and then try to uninstall them.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 17, 2010
SOURCE: MY GOOGLE BROWSER HAS CRASHED
Simply reinstall, TO another Directory I suggest C:\Chrome That should sort you out.
Anonymous
  • 13 Answers
  • Posted on Nov 11, 2010
SOURCE: whenever i start google chrome,it
Try uninstalling again, and after uninstalling, remove the 'Chrome' folder from the application data folder.
If you are using Windows 7, the folder will be located at:
C:\Users\(USER)\AppData\Local\Google\Chrome
Substitute "(USER)" with your user id. For instance, if your user id is 'Fred' then your folder would be at:
C:\Users\Fred\AppData\Local\Google\Chrome
If you are using Windows XP, the folder will likely be located at
C:\Documents and Settings\(USER)\Application Data\
Delete only the 'Chrome' folder, and not any other such as googleearth.
If you're unsure of what you're doing, you may also rename the folder to something like 'wasChrome', that way the folder isn't available to the future Chrome installation, but is still 'there'.
Once you've gotten rid of the Chrome folder, reinstall and this may solve all your problems.
I have recently changed to sky for my internet. i can sign i to sky but it then brings up the yahoo sign in page. i sign in with my password etc but it doea not sign me in and my laptop crashes. i am
Hi Angela
you can try this for Chrome
Google Chrome
  1. Click the Chrome menu icon 4003bf51063e6dc3e65713ae5b50ee797ee6.
  2. Select Settings.
  3. Near the bottom of the page, click Show advanced settings.
  4. In the "Privacy" section, click Content settings.
  5. Enable or disable cookies:
    • To enable cookies, select Allow local data to be set (recommended).
    • To disable cookies, select Block sites from setting any data.
  6. Click Done to save or if you have any of these browsers on your system you can try this:
  7. Mozilla Firefox
    Firefox 29.0 and newer
    Operating systems:
    - PC: Windows Vista, and 7
    - Mac: OS X 10.5, 10.6, and 10.7
    1. Choose the menu option for your computer:
      - PC: Select Tools ' Options.
      - Mac: Select Firefox ' Options.
    2. Select Privacy.
    3. Under "History," make sure the "Firefox will:" option is set to Remember history.
    4. Click OK.
    5. Close and restart your browser.
    Apple Safari
    Safari 5.0 and newer
    Operating systems:
    - PC Safari 5: Windows XP, Vista, and 7
    - Mac Safari 5: Mac OS X 10.6 and 10.7
      - PC: Select Tools (gen_sfristtgicon_01.png gear icon) ' Preferences.
      - Mac: Select Safari (gen_sfristtgicon_01.png gear icon) ' Preferences.
    2. Select the Privacy tab.
    3. Select the "Block cookies" option, Never.
    4. Close the "Preferences" window.
    6. Hope that helps
2helpful
5answers
Google chrome keeps crashing not sure why
You need to check out all these:
1. Check for Conflicting Software:
- Some third-party software can cause Google Chrome to crash. When this happens, you'll see the message "Whoa! Google Chrome has crashed. It's possible that you have malware that can cause Google Chrome to crash.
- Google Chrome has a hidden page that will tell you if any software on your system is known to conflict with Google Chrome. To access it, type chrome://conflicts into Chrome's address bar and press Enter.
- You can try to fix these crashes by updating, disabling, or uninstalling any conflicting third-party software listed in "about:conflicts" on your computer. Also, take a look at Google Chrome's known issues for specific solutions to resolve crashes caused by some software.
2. Scan for Malware
- This includes malware and network-related software that interferes with Google Chrome. Malware can also interfere with Google Chrome and cause it to crash.
- You can try using Malwarebytes, or other anti-virus software to scan for and remove malware or you can also try searching the web for information related to any conflicting modules listed on the chrome://conflicts page (Windows only), to see if there are other steps you can take to remove malware.
- Many crashes are caused by malware. If you're experiencing frequent crashes, try scanning your computer with antivirus software.
3. Solve Flash Crashes
- We have found that the Flash plugin Chrome includes can cause it to crash in some cases. If you are seeing regular Shockwave Flash crashes, you may want to try disabling the internal Flash plugin and using the standard Flash plugin in Google Chrome.
4. Switch to a New Profile
- Chrome crashes may be caused by a corrupted profile. You can test this by creating a new profile from Chrome's Settings screen. Open the Settings page from Chrome's menu and click Add new user under Users.
- Change to the new profile after creating it and see if the crashes continue to occur. You can sign into Chrome with your Google account to sync the data from your old profile. However, Google recommends you don't copy any files from the old profile folder by hand - they may be corrupted and causing the problem.
5. Fix System File Problems
- Google recommends running the SFC.EXE /SCANNOW program to check for - and fix - problems with protected system files on your Windows system if you are encountering crashes. To do this, locate the Command Prompt in your Start menu (press the Windows key and type Command Prompt), right-click it, and select Run as Administrator.
- Type the following command in the Command Prompt window and press Enter:
SFC.EXE /SCANNOW
- Windows will scan your computer for problems with system files and fix any problems it finds.
6. Hardware issues
- It can also cause Chrome crashes. You may want to test your computer's RAM and ensure it isn't faulty.
· If still problem not solve, maybe you should try these simple steps:
1. Try restarting your computer first. It could be that the computer has just encountered a slight glitch on your system, which is causing things to not work properly.
2. Remove and Re-install the Google Chrome application. Doing this will allow your computer to read the files a lot better and faster, and also repair any damaged or corrupt files that have been causing the issue. To remove the Google Chrome application, first insure that you have another browser, such as IE or Firefox, click "Start, Control Panel, Add / Remove Programs," locate "Google Chrome" click UNINSTALL next to it. When the application loads, select "REMOVE" (not repair). Follow the uninstall process, and restart your PC. Problems uninstalling or re-installing Chrome indicate mal- or spy-ware, which must be dealt with.
3. Remove any extensions that you have on Google Chrome. Although they are a great way to personalize your Internet browsing experience, they are not so good for speed and functionality, as many can cause the application to crash. To remove any extensions follow these steps: Open up Google Chrome. In the address bar type chrome: //extensions. Click Uninstall, or Click Disable if you think you may use the add-on in the future. Restart your browser.
4. Disable plug-ins. Chrome can get bogged down with plugins that you aren't using, also. Type about: plugins into Chrome; it will redirect to chrome://plugins. Disable any that you aren't currently using.
Hopefully your Google Chrome crash problems are gone. Hope it works. Sharing is always caring.
1helpful
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
2answers
Google chrome keeps going snap why?
"Aw, Snap!" IssueYou may see the "Aw, Snap!" message if a webpage crashes unexpectedly.
SolutionsIf a webpage crashes unexpectedly, you can simply reload the page. If you're seeing the "Aw, Snap!" message for every page you visit, try the solutions below:
Some anti-virus or firewall applications, such as Symantec Endpoint Protection, can prevent Google Chrome from working properly. Test whether such applications on your computer are causing the error by turning them off temporarily. Then try opening Google Chrome again. If you are able to open the browser, you'll need to create an exception in your anti-virus or firewall settings for Google Chrome. Once you've done so, you can then re-enable the applications.
Conflicting applications that users have reported include the following:
  • Spyware Doctor
  • Comodo firewall
  • McAfee Enterprise
  • McAfee Virus Scan
Try disabling your extensions one by one to see if a particular extension is causing the problem.
  1. Click the wrench icon chrome_toolsmenu.gif on the browser toolbar.
  2. Select Tools.
  3. Select Extensions.
  4. On the Extensions page, click Disable for the extension you'd like to temporarily remove.
Go back to your list of extensions at any time to re-enable disabled extensions. You may need to refresh the page in order to use extensions you've re-enabled.
If the browser continues to display the "Aw, Snap!" message, your user profile may be corrupted.
To create a new user profile, follow these steps:
  1. Exit Chrome.
  2. Find the "Default" folder. It's usually located in the following locations:
    Windows
    • Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome\User Data\
    • Windows Vista and Windows 7: %LOCALAPPDATA%\Google\Chrome\User Data\
    Mac OS X: ~/Library/Application Support/Google/Chrome/Default
    Linux: ~/.config/google-chrome/Default
  3. Rename the folder as "Backup default."
  4. Restart Chrome.
it is taken from support site..
Regards
I'm trying to acess any page by google chrome and I get this message everytime : Error 101 (net::ERR_CONNECTION_RESET): unknow error. Now I got to acess some sites like yahoo.com and gloco.com but the...
Hi there.
The best way to solve this problem is by uninstalling hte google chrome and repairing the operating system. Then install again the google chrome because the internet explorer had crash and got corrupted.
Regards
DEP closes IE.
Might I suggest turning on or off DEP. Right click my computer-select Properties- select Advanced- select Performance- select Data Execution and select Turn on DEP. You will have to restart for changes to take effect.
3answers
Internet Explorere keeps closing down
Data Execution Prevention (DEP) is a security feature that helps prevent damage from viruses and other security threats by monitoring your programs to make sure they use system memory safely.
Here is a link to an excellent article on DEP.
Whie it will show you how to turn DEP on, it will also take you to the control panel that will aloow you to adjust your settings.
http://windowshelp.microsoft.com/Windows/en-US/help/1d9bb9b4-f6ba-466d-ac2b-7b8c4f8361611033.mspx
6helpful
Google chrome i cant uninstall
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
