Dell 1815dn All-In-One Laser Printer Logo
Posted on Oct 10, 2012
Dell 1815dn has loud beeping noise and display says door open front door
1 Related Answer
Anonymous
  • 160 Answers
  • Posted on Jun 16, 2011
SOURCE: Front door open message on display of dell 1815dn printer
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
How do you print an envelope on a Dell Laser MFP 1815dn
when printing enevelopes always ALWAYS THROUGH THE BYPASS open front door and feed thru there. on the bypass is image to let you know fce up or down follow that. also change settings on pc when printing envelopes or cardstock etc.
Dell 1815 keeps saying door open when it is not.
The front door switch has gone bad which is part of the High Voltage Power Supply. You need to replace the HVPS (part# WH773). This should clear your problem right up. Iteminc.com has this part and ships same day.
I have a Dell 1815dn all-in-one laser printer. I have a "open door front door' error message rendering my machine inoperable. Any suggestions on how to clear this?
Currently have a Dell 1815 - keeps saying Front door is open and will not print. Have tried everything - from turning off printer, unplugging, changing toner, etc.
Door open Front door message. the copier does not work
plz check the printer carefully, there may be some dislocation of some parts which is preventing the front door from completely closing. post back if more assistance is req.
Dell 1815 dn - bogus front door open message
6helpful
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
5helpful
Front door open message it won't print
There is a switch inside the front door that is not making contact when the door closes, making the printer think that the front door is open. The switch is recessed in the housing. Look for a plastic knob that protrudes from the front door that will mate with a hole in the frame. Inside this hole is the switch. Try activating the switch manually with a screwdriver to make sure the switch is functioning. If it is, you will need to take off the cover and reposition the switch forward. If it does not activate manually, the switch must be replaced.
2answers
Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
