Dell 3100cn Laser Printer Logo
A
Anonymous Posted on Oct 10, 2012
How I can fix the dell error 016-302 restart printer on Dell MFP3115cn
5 Related Answers
Anonymous
  • 188 Answers
  • Posted on Oct 02, 2008
SOURCE: 010 397 Error Message on Dell 5100cn
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Anonymous
  • Posted on Nov 09, 2008
SOURCE: Error 003-343 Dell 3110cn
Open the printer using the button on the side top right. You will see two gray things with arrows going left and right. move them both two where you can take out the piece it is hold in. Pull out the large piece and put it back in. Close the two gray things to lock it back into place. Close the printer and restart it. It should fix your issue. It must of became loose at one point when I was moving so I fiddled with it and turns out that was the issue. It works great now!!
Anonymous
  • Posted on May 18, 2009
SOURCE: RESTART Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Anonymous
  • Posted on Jun 24, 2009
SOURCE: Error Code 004-332
I tried this solution but wasn't quite sure how it's possible.
"Pull out the drum. Open the front door. Then close back this door then at the same time, move
the carousel around back or forth. The carousel now is able to be free to rotate. During rotating
you try to pull out the catridge. If it is locked, then adjust it to the position to be free."
Instead i pulled out the drum unit and pushed down with a bit of force on the toner carousel. I heard the gears grind which didn't sound real pleasant but the error went away. Instead I received an error message this time to remove and reseat the Cyan toner. Tried this multiple times w/o luck so i replaced the Cyan toner and it freed it up. Now I'm getting a paper jam message but there is no jam. Stuck again but making progress...
pineworks
Clive
  • 4362 Answers
  • Posted on Mar 02, 2010
SOURCE: My dell A960 printer has hardware error 0502.How
Dell A960 All-In-One InkJet Printer
Error 0502 and 0504
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
What is the best way Fix Dell Printer Error Code 009-654?
It is an error code that is a common technical error that manifests due to poor quality prints and smudged color. It generally indicates that the printer firmware is outdated or the CTD sensor is not clean.Jan 27, 2021
Steps to Fix Dell Printer Error 009-654 - Tech Support Expert
https://techsupportexpert.com > Blog
Solved: DELL C1760NW ERROR CODE 009-654 - Printers
https://www.dell.com > community > Printers > td-p
Thank you for reaching out to us. The error code shows that there is an issue with the printer ADC sensor. If you have already restarted printer multiple times ...
Where do i find the drum on my dell mfp3115cn or the coronas?
There is a drum on each of the toner cartridges.
This printer does not have corona wires.
6helpful
3answers
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
What does error code 006-370 mean?
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section18.html
see this page for detail, i hope this helpfull, if you think this helpfull please rate very helpfull or helpfull. thanks for using fixya
2helpful
2answers
1helpful
2answers
Dell error 007 371.How to solve or reset this problem ?thanks
http://support.dell.com/support/edocs/software/dtk/2.4/CLI/pdf/dtk24cli.pdf look here codes are posted
2answers
Dell printer
Error code: 004-332
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in.
1helpful
2answers
My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
