I have the prima ht 8104 sourround system and lost the remote! does anyone know how i would go about getting a new one or is there a universal remote that will work with this??? Without the remote the system is useless because no function buttuns on the head unit!!
thank you
SOURCE: lost the remote
If the universal has a "code search" function, try that. If not get one that does and likely you will find a code that works.
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
SOURCE: three-digit code for prima tv for universal control
If you can't find it under prima look under legend
If not read your manual and depending on the remote you have a option for the remote to find the code by itself
Just have to follow the instuction in the remote user's guide in the place that says "Brand not listed"
Good Luck
-John-
SOURCE: can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
The easiest thing to do would be to go to an electronics store, look on the back of the remote control package and look for Durabrand.
It should come with a booklet with the setup codes.
Thats all I got for now.
Hope that helped, good lukc, please rate.
lost my remote control player dvd portable
Lost the "green" remote for the Kawasaki PVS2970S Twin Mobile DVD system
