Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
When filling on rinse cycle machine will drain water continuously without ever filling. What is causing it to drain? Machine is about six years old. It works fine otherwise.
  • Anonymous Mar 21, 2014
    Whirlpool quiet wash plus leaks out of vent when draining
  • 179 Answers
Your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
SOURCE:
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't rinse or spin
clean filter and pump
Mar 19, 2010 | Washing Machines
Whirlpool washer stops in the middle of cycle does not rinse and
If your washer stops at the same time each wash, you have a dead spot in your timer. It will need to be replaced. .
Aug 15, 2009 | Washing Machines
Two year old Whirlpool washer started failing to advance from the rinse cycle to the spin cycle a couple of weeks ago. However, the water would drain through and run until you manually advanced the system...
Hi, I just want clarification. Is the washer filling to a point when it starts draining the water before it starts to agitate? If this is the case, check the end of your drain hose and make sure that it is as high as the top of the washer. Make sure that where it goes into the drain pipe that it is a loose fitting so that air will **** back into the drain hose. Please let me know if I have given you the right information or if I have missed what you are describing so I can assist you further.
Thank
Vic
Jul 13, 2009 | Washing Machines
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,355 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
