It has had a new heater element fitted already and works fine, I think it may be the thermostat, it sometimes works ok then all of a sudden starts playing up again, as said above it resets itself to 160degrees and starts flashing like it would when you initially start the temperature setting programme.
If it keeps resetting it this way, I would suggest that you get it repaired. Things like this can be difficult to fix on your own. It might be possible to do it by looking in a manual, but it might just be easier to get someone to repair it. I hope you are able to get it fixed, since this is a pretty significant problem! http://www.allapplianceservice.biz/Services/
These answers are not a solution to the problem!!!!
SOURCE: Whirlpool Oven Shutdown Fuse
you need a new fuse it is not resetable should use renches but be carful if not comfortable call service
SOURCE: Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
SOURCE: Whirlpool AKZ 446 Electric fan starts but oven
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
SOURCE: I have a Whirlpool AKZ451 built in oven that is
yes, or the oven control itself,make sure also to closely inspect the element itself for any "HOT-SPOTS" where its getting a high resistance area and not passing all the current needed to heat the element
SOURCE: Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
If you need further help, Iām available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
