Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon PIXMA MP530 - Need help to setup fax/tel mode properly
Please provide instructions on how to setup my machine to work with my phone line properly. First, I currently have my machine on fax/tel auto sw so that the machine can accept faxes and voice calls automatically. Second, my phone that is hooked up to the machine will ring (the machine does not ring) when calls come in and my call display works properly, BUT my voice message service (that I subscribe to thru my phone company) DOES NOT kick in if I don't answer the call. I DO want my voice msg service to work when I am unable to answer incoming phone calls. BUT instead of the voice msg service kicking in, the call will route to the machine - so the machine then rings as if the call is a fax. BUT the call is NOT a fax, but just a regular phone call. Third, when a fax is coming in, my phone rings (not the machine) and the call display shows the number and then the machine receives the fax - BUT the machine doesn't ring. I know the settings are not right. Can someone help me to choose the right settings so that I can receive faxes when they are just faxes, receive calls when they are just calls and have BOTH my call display and voice messaging system work properly when calls do come in. Thank You.
4 Suggested Answers
SOURCE:
yooperbud
  • 8637 Answers
SOURCE: Canon Pixma MP530 - Want to setup machine & phone properly
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
prnt master
  • 110 Answers
SOURCE: Canon PIXMA MP530 incoming faxes are blank
please refil your fax Machine cartridge.
Posted on Jul 30, 2009
komguy
  • 2306 Answers
SOURCE: How do I set fax and phone on one incoming line?
You can't do that automatically on one line unless you ask for distinctive ring from yyour phone provider. Dist. ring gives one pattern for fax and a different ring for regular calls. Otherwise the fax needs to be set to manual and you answer each call and press fax start when you hear fax tones.
Posted on Oct 16, 2009
I have a cannon pixma mx870 printer and I cannot receive faxes. I have unplugged all the phones in the house and checked the phone line that is hooked up to the printer.
Plug a phone into the little telephone extension lead that came with the machine to see if you get a dial tone. If you do then get someone to send you a fax and answer it with that phone. press the start button and it should go into receive. Make sure you are using the genuine canon lead too and its plugged into the "Line" socket and not the "Tel" one.
Aug 27, 2011 | Canon PIXMA® MP530 All-In-One Printer
I own a Canon Pixma MP530 all-in-one fax,copier, printer,scanner. I cannot send or receive faxes since I switched my Comcast voip phone line from my office to my home phone, along with my MP530. The fax...
First try one step. The line which you have connected with the Fax, unplug any other phone from that line.
Call that number and see whether it rings or you get a fax tone.
Sep 13, 2008 | Office Equipment & Supplies
Not able to send fax , new machine ..may be not set properly ..to the mode ( setting the Telephone Line Type) as per instructions but cant find that setting on machine , I am in Sydney..if someone can help...
It's in the fax menu under general setup, and the choices are tone or pulse. It will only work on an analog phone line, it won't fax on a digital system like most comercial bldgs. use.
Sep 10, 2009 | Canon PIXMA MX310 All-In-One Printer
How to change fax settings to accommodate distinctive ring
Go to this link. In the search window in the center of the screen, type "drpd setup" and click on the Search button. Select the option "How do I set up DRPD". You should see step by step instructions to set it up.
Feb 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Dec 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I can send faxes, but not receive them on Canon Pixma mx310
Do you have the phone you are answering with connected through the fax machine? If you have the machine set in 'tel priority' mode, the machine will not begin receiving a fax until you press 'FAX' and the 'color' or 'black' button. Alternatively, if you have your phone connected to the 'telephone' jack on the machine (next to the 'L' jack), you can press '2' and '5' on the telephone keypad to turn the machine on in fax receive mode.
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Sep 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax/tel mode
Go to the following link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371#SupportDetailAct
Click on Support and Service Tab
Enter -- answering machine -- into search and click search
Click -- Fax Machine is answering all incoming calls
Click -- Setting the Fax Receive Mode
Observe -- Ans Machine Mode
Dec 23, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
52 people viewed this question
Clive
Clive
old marine
old marine
Ekse
