Otpoint aqxx149 not draining water and leaking
You need to check the outlet hose of the washer, make sure it is not kinked or restricted in any way.
Check the pump filter which is located behind a removable front plastic panel at bottom of m/c.
Unscrew the scews and remove the filter by unscrewing anti clockwise, be careful as there will be some water run out., clean filter and replace it
Check inlet hose for leak, and dispenser hose for soap blockage.
PLz rate my solution.
Thanks.
