Won't rinse... goes through motions, but nothing is coming out of the spouts. No codes reading on display.
SOURCE: Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
SOURCE: jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
FIXED!!! Like recommended from "Venice 298,' manufacturer recommends taking the ground fill trap out, slamming it up and down a few times. This worked. It must have had some residual coffee grounds stuck, not allowing the water mechanics to move where they were supposed to. I am pleasantly surprised this was the easy fix!!
