I have tried cleaning the igniter on that one specific burner but the burner still clicks once the flame is going.
SOURCE: ignitor click and sparks, but no flames
there are two small holes at the base of the burner where the pipe goes up to it but doesn't touch. i had the same problem and it turned out that these two holes were clogged. i just straightedend a paper clip and solved the problem
SOURCE: Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
SOURCE: Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
SOURCE: my gas cooktob burners keep clicking as if it was
caller a gas repairer to check the pipes connecting the burners they should be a linkage somewhere
SOURCE: I have a Jennair Gas
Did you cleaned the burners with liquid or by mistake did any water got spilled on the burner area.Sometimes the burners or parts below the surface can get wet or dirty and cause the clicking. If you wait a few days for everything to dry out, it can stop on it's own.Or you can use hair dryer to dry the moisture/water got collected/settled on the burner area.But if this is not the case,and burners are proper dry and still the clicking,then this problem is related to faulty igniter.The igniter needs to be replaced.
------------ first try cleaning the burners and igniter with dry cloth,you can also use air blower/hair dryer to blow out any dust if collected.Then try.If its got wet/ moisture then it will take few hours to get completely dried up then it will work.but if still same exact problem then its faulty igniter causing this.
To order replacement igniter,click the link below:---
http://www.repairclinic.com/PartDetail/Spark-Electrode/1035559?modelNumber=JGC9430ADS
This will help.Thanks.Helpmech.
I am going to try unclogging the two small holes and see if that works. Thank You.
